Results 1 to 4 of 4
Thread: VAG OEM Triplex Aerial
    Apr 2005
    Sweden
    Lightbulb VAG OEM Triplex Aerial
    What about this? Can we use this in some way for GPS & Radio antenna for Car PC?
    http://www.vwnavi.com/vwnavi/photos/...ls.php?album=8
    Elsewhere
    Yes, it can be used.
    You'd need a GPS unit that has the provision for an external antenna. You can also go with an OEM GPS unit. Search the forums here for OEM GPS and you'll get all the info on that. It's more expensive, but the people that use them are ecstatic with the results.
    How about the Wiki?
    Apr 2005
    Sweden
    Searched as you suggested. will this work? I have a BU-303 USB GPS.
    And this guy soldered an external antenna wire from the BU-303.
    is the VW OEM Antenna 5v active?
    BU-303 Antenna Modification
    Picture of an opened BU-303 GPS USB unit, with the soldered extenal antenna connector.
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    You could do that, you'll have to find the specs on that antenna somewhere, I would image that it's active though.
    肚子笑痛了
    S60 Install
  1. Pics of OEM LCD installs here:
    By Scouse Monkey in forum Fabrication
    Last Post: 04-13-2014, 07:48 PM
  2. OEM GPS mod. Writeup + Pics
    By IntellaWorks in forum Hardware Development
    Last Post: 07-04-2006, 03:59 AM
  3. Oslon 8" TV aerial no sound
    By Stooboy in forum Car Audio
    Last Post: 09-27-2005, 06:55 AM
  4. UK Aerial Photos
    By stevieg in forum GPS
    Last Post: 07-21-2005, 12:14 PM
  5. OEM looking control--use power window switches?
    By telekineticfool in forum Input Devices
    Last Post: 01-04-2004, 12:06 AM
