Other options are
Ozi explorer - this does not do turn by turn.
Mapsource - have a feeling this is awefully similar to Copliot.
IMHO the best option at the moment is Destinator when used with MapMonkey or Freedrive.
I am looking for some GPS software for my carputer. I have done some searching and so far I have found these:
CoPilot Live
Destinator
TeleType WorldNavigator
Is there anyone running these or any others that I am not aware of?
Please share your experience with them - the good/the bad, etc.
Also, if there happens to be someone in Melbourne - north/eastern suburbs who has a working setup and wants to show it of, I would like to see![]()
Other options are
What version of Destinator are you using?
www.mapmonkey.net
(Based around Destinator 3)
Fox Mulder
2001 Toyota Avalon Vxi
Toshiba TE2000 Laptop 1Ghz BU-353 Black Xenarc 700TSV HD & Analogue TV FM DVD/CDRW Car2PC Adaptor
2004 Toyota MR2
Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Lilliput 7" TS BU353 DiNovo Mini Car2PC ODBII
Destinator 3 with MapMonkeyOriginally Posted by marenko
I am using Dest 3 with MM. It works reasonably well.
Occasionaly it gets lost and tells me to turn right, when there is no right turn there! etc etc,
I go to a small country town in NSW regularly and it gets a bit lost enroute, telling me to turn into a paddock!!
jaytyn, I see you are local. How well does it work around the suburbs of Melbourne? Was it a hassle to set it up and get it working?
Can you buy Destinator for pc/laptop a little more cheaply than retail.
Map monkey is great! Well worth checking out.
Dave
Is D3 still available to use under MapMonkey ? the last i heard the only SDK you could get was for Destinator PN. then you couldn't buy D3 anyway as they have brought out the newer version. I am interested in getting MapMonkey working with D3 as well for use in Australia. Every thread I read seems well out of date.
