Results 1 to 9 of 9
Thread: Holux GPSlim 236 Help
    Variable Bitrate ramy_zohair's Avatar
    Sharjah, Emirates
    Unhappy Holux GPSlim 236 Help
    I'm problems getting my receiver to work under XP. I have i couple of questions. So anybody having this receiver??
    1) I was told at the shop when i bought it that i wont be having trouble getting it to work with Garmin's Mapsource & nRoute. But when its not connected I get see the maps in full detail, when I start tracking the details switch to lowest although it shows maximum in the preferences. Is it a compatibility issue??? Any solutions?
    2) I couldn't get it to work on windows XP (only works on 2000). It detects it and and pairing is fine (its bluetooth), but the virtual COM port to Bluetooth device is showing in the services, but it doesn't seem to be active.
    I know the receiver is working fine as it works flawlessly with my nokia 7710. Its got great lock and everything im getting 9 - 11 sats when placed on the dash (having a dark tint too)
    Anybody please.
    Sharjah, Emirates
    Nobody for help??
    FLAC Marvin Hlavac's Avatar
    May 2005
    It should work under WinXP, no problem. But I don't think it will work with your nRoute. I do believe nRoute will not work with a standard NMEA receiver. It requires proprietary Garmin hardware :-(
    Sharjah, Emirates
    Garmin is the only supplier of Middle East Maps. What would the solution be??
    Variable Bitrate Fox_Mulder's Avatar
    Melbourne, Australia The Truth Is Out There
    Buying a Garmin reciever might work.
    Fox Mulder
    2001 Toyota Avalon Vxi
    Toshiba TE2000 Laptop 1Ghz BU-353 Black Xenarc 700TSV HD & Analogue TV FM DVD/CDRW Car2PC Adaptor
    2004 Toyota MR2
    Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Lilliput 7" TS BU353 DiNovo Mini Car2PC ODBII
    Sharjah, Emirates
    What do you think of the Garmin GPS 10 (bluetooth). does is work as good as the GPS 18 (usb)??
    Does the bluetooth version support the industry standard NMEA 0183 data format, or is it like the usb version (using only the GARMIN proprietary format)??
    The price for GPS 10 : $230
    The price for GPS 18 + Europe's Maps: $176
    If they had the oem version of GPS 18, i would have gone with that. But Europes maps
    Sharjah, Emirates
    by the way thanks for the replies guys. I almost gave up on GPS
    I would probably go for the USB, I just have a feeling it's better to go for a hard wired connection where practical. Less chance of things stuffing up!
    Fox Mulder
    2004 Toyota MR2
    Sharjah, Emirates
    Too bad. i loved the holux receiver. I think i will have to return it then and go with garmin.
    Thmx Fox for ur help.
  1. Replies: 9
    Last Post: 04-22-2006, 09:22 AM
  2. Holux
    By ramy_zohair in forum GPS
    Last Post: 11-29-2005, 02:26 PM
  3. Help me with this GPS
    By kickercivic1 in forum GPS
    Last Post: 09-01-2005, 09:11 PM
  4. Replies: 2
    Last Post: 07-29-2005, 12:09 PM
  5. Rikaline 6010 GPS or Holux 210
    By edmonton_mr2 in forum GPS
    Last Post: 01-15-2005, 03:35 PM
