Results 1 to 10 of 19
Thread: Gps won't get a fix
    Nov 2005
    Netherlands
    Gps won't get a fix
    I purchased a GPS unit from holux after reading the results on this forum. It's the new gr213 with sirfIII chipset. The thing has worked flawless for about 1 week. Since a few days it won't get a fix anymore I've tried reinstalling but it seems that the software is working correct. When I open gps viewer I get this:
    Is the GPS dead?
    Nov 2005
    I had the same thing when I tried using the gps viewer. For some reason it would not work, but the gps unit works fine when using a mapping software.
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    if it has the Sirf III, couldn't you enable the WAAS to help a bit? And are you running it with a "cold" start?
    Nov 2005
    Netherlands
    Quote Originally Posted by binary.h4x
    I'll try it! I've tried al the starting modes.
    Nov 2005
    Netherlands
    aargh, after waiting for 10minutes the thing finally got a fix. Drove for 10min and everything was ok. 30min later I started the car again and eveything worked fine.
    Today, no fix ... grmbl..
    Raw Wave tj!2k4's Avatar
    Oct 2004
    are you parking the car overnight where it doesn't have a view of the sky?
    Constant Bitrate faichiu's Avatar
    Where did you place your GPS unit?
    Mine often got fix before It enters OS even cold start in the morning.
    98 Honda civic
    In-Dash LCD Monitor K-301
    cappuccino EZ3
    PIII-1.2GHZ
    256MB PC133
    40GB HD
    Holux GR 213 Sirf Star III GPS
    IguidanceV2
    CNX-P1900 power supply
    Sound Blaster Live USB
    Nov 2005
    Netherlands
    The gps is at the back of the car.. underneath the rear window. Where it has worked for a whole week. So it has a clear view of the sky. If I boot the pc, wait for 20min so that it get's a fix everything is ok. Until the gps get's 'cold' and then I have to wait again.
    Mar 2004
    Marietta, GA
    You may want to experiement by placing it in different places in the car. I have gone through 2 gps units thinking the units were the problem. After I got my second unit, I was driving and it got knocked out of place, but I noticed it got a lock in like 15 seconds (instead of the former 5-8 minutes). In short, my problem as that I chose a location based on aesthtics (center of the dash, nearest to the wind shield) and not by best function (center of the dash, to the left of the car, right in eye view of the front passenger). If you have a waterproof unit, put it on the roof of the car. Good luck.
    Nov 2005
    Netherlands
    It's been a few months and I still have this problem. I've been playing with drivers/com drivers jus to make sure it's not my own fault. When i unplug the usb drive and replug it in another port it always works like a charm!
    At which baudrate should the comport emulator run? 4800?
  1. GlobalSat BT-338 Review
    By tom2112 in forum The Review Palace
    Last Post: 06-27-2005, 12:02 PM
  2. Newbie's guide
    By EBFoxbat in forum Newbie
    Last Post: 02-08-2005, 11:06 AM
  3. Think I foubd BUG with map monkey and media car
    By cdevelasco in forum MM Bugs
    Last Post: 02-02-2005, 10:52 PM
  4. D3 with USB GPS after HIBERNATION
    By BOND007BE in forum Map Monkey
    Last Post: 11-26-2004, 02:54 PM
  5. Replies: 4
    Last Post: 09-15-2004, 05:37 PM
