Page 4 of 4 FirstFirst 1234
Results 31 to 39 of 39
Thread: IGuidance (Navigation) and Music Solution!
  1. #31
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Rafster
    ..Cough..Torrent..Cough..
    Peace,
    Rafster
  2. #32
    Dec 2005
    Talking
    Quote Originally Posted by Civic03
    1. I want the ability to listen to Music while the navigation software does its thing
    2. Mute the music when the Nav prompts you
    3. Be able to have Nav work in the background and only show up when it's prompting you for your
    you need the source of the software, I think
  3. #33
    Constant Bitrate reggiek945's Avatar
    Apr 2003
    Oklahoma
    I'm not sure if I'm reading this right or not but I use Iguidance while listening to music in my truck all the time. When it prompts me the music level goes down until after the prompt is done. (Are you talking about music from another source like radio, cd?) This is when Iím playing mp3ís using my carputer.
    Iguidance
    1. Tap Menu, Volume.
    2. Select the volume level.
    3. Tap the Test button to hear the volume level.
    4. Tap OK to accept or Cancel to reject the change and return to Map screen.
    I'm not sure if this is what you need but it works great for me.
    Reggie
  4. #34
    Maximum Bitrate Civic03's Avatar
    Dec 2005
    Hi Reggie, yes I'm talking about any source. Obviously the computer has to control the source for this to work; i.e. I don't think the carpc can lower my HU volume unless there's a way to do this and I don't know about.
    For any other volume that's coming from the PC I would like this. I also plan on using Sirius so this will come in handy as the computer will control Sirius and hopefully the volume. Are these settings above done in IG?
    PROGRESS 95%[//////////]Complete - Software configurations
    Current Task: Just adding on...
    Needed:wireless keyboard/mouse
    My Carputer Blog
    Car System Site
  5. #35
    Apr 2003
    Oklahoma
    Yes these settings are in IG, It works great for me. Let me know how it goes for you.
    Reggie
  6. #36
    Variable Bitrate Hark's Avatar
    Feb 2005
    Atlanta, GA USA
    What about taking more of a hardware approach to the problem of muting the music when nav instructions are given? I use a laptop for my CarPC, which has a built-in sound card, and I also have an Audigy ZS Notebook card in the PCMCIA slot - so I have two sound cards.
    I've read that you can configure WinAmp (which is used by RoadRunner) to select which sound card it uses. I'm wondering if I can set WinAmp to use one sound card, and then have iGuidance use the other. This way I'll have two RCA cables, each with different app audio output. Then I can use an audio switcher device like this to automatically switch the output being sent to the car amplifier when any sound is received from the iGuidance output cable, and when it's done, switch back to the WinAmp cable.
    I'm not sure this will work yet, but I thought I'd float it here and see what anyone thinks.
  7. #37
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Quote Originally Posted by reggiek945
    I'm not sure if I'm reading this right or not but I use Iguidance while listening to music in my truck all the time. When it prompts me the music level goes down until after the prompt is done. (Are you talking about music from another source like radio, cd?) This is when I’m playing mp3’s using my carputer.
    Iguidance
    Reggie
    I think that what this does is increasing some how the volume for IG (no the other way around) it works for me too tho
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
  8. #38
    Maximum Bitrate psyrex's Avatar
    Jun 2005
    Oakland, CA
    FYI, there was some discussion about hardware switching (Navigation voice mutes my radio...is this possible?) with some links to devices.
    -psyrex
    Gen 1: Pentium 3 1GHz - ATX - 2005
    Gen 2: Pentium M 1.6GHz - ITX - 2006
    Gen 3: Pentium M 2.0GHz - 5.25" SBC - 2007
    Gen 4: (coming soon: Core2 Duo - 3.5" SBC - 2009)
    ...it never ends
  9. #39
    New York
    While your all going into very complicated sol'n, why not start simple?
    IE, Wave volume is 50%. If you double the current gain of the all the wave files iGuidance uses, then the Wave volume can decrease by some value X. Possibly, half. taking this assumption, then Wave Volume should be set at 25%. This would lower music in the background while the Wave file should still sound loud because of the gain change.
    Mark
    Website: http://www.greenpowerenthusiast.com/
    Car'Puter Project
    - Xenarc 700TSV
    - MSI RS482M-IL Mobo + AMD Turion MT-32 (25W)
    - 1x 256MB Corsair XMMS DDR400
    - M2-ATX
    - Belkin 802.11G W-Nic
    - Garmin 15H GPS
    - WinXP SP2 (NLited)
  1. I want to listen to music (radio) while using GPS navigation
    By ummagawd in forum General Hardware Discussion
    Last Post: 08-12-2008, 01:49 AM
  2. Navigation for 350Z
    By Dino S in forum Car Audio
    Last Post: 06-15-2005, 07:42 AM
  3. copilot users: your software solution?
    By aoLhaTer in forum Software & Software Development
    Last Post: 01-15-2004, 02:17 PM
  4. 4am MUSIC Console 1.5 (music jukebox)
    By OvernightTech in forum Software & Software Development
    Last Post: 09-01-2003, 03:10 PM
  5. Anyone use an IPOD for music serving?
    By -al- in forum General Hardware Discussion
    Last Post: 08-24-2003, 12:54 PM
