Results 1 to 5 of 5
Thread: BU-353 extension cable
    Jan 2005
    Question BU-353 extension cable
    Hello guys!
    I have the Bu-353 working very well with Iguidance but the cable is to short to mount the GPS outside my GrandCherokee, so I bought an USB extension like 3 feet long and the GPS is not working... when I plug it to the USB port it sounds the windows bell like it was detected, but when using the scan ports utility it is not found...
    I changed the USB extension for another shorter, 1.5 ft and still the same problem.. If I don't use the extension the GPS works fine...
    Any ideas???
    Dec 2005
    maybe it doesn't have enough juice to power the receiever? i'm just guessing.
    Raw Wave EsKALad's Avatar
    Jan 2005
    Chicago, IL
    i dunno what to tell you. i had a bu303 running about 10 foot extension with no problems!
    i got dat ***** sittin on 22s! SUPERMAN EDITION!
    Jun 2005
    I have the bu353 and will test today with my 10 ext.
    http://www.mp3car.com/vbulletin/classified-archive/70918-fs-ft-laptop-memory-internal-laptop-wifi-card-hd-bluetooth-post759606.html
    FS FT Thread
    96 Eagle Talon TSI AWD
    Custom blue LED interior and Dash, Buddy club2, ViS Fenders, Phillips Ds2 Bulbs, Valeo-Fresnal ECE H7s, Mitsubishi Ballasts
    Jan 2004
    Jersey/NY
    Quote Originally Posted by skadoo323
    skadoo may be right. What are you plugging it into right now, directly into the mobo's usb port? Try a POWERED hub (not the self-powered junk), and perhaps try in your home computer. Some USB ports are just weak, and don't give many amps to them.
    good luck
  1. Can't get the BU 353 to work with Destinator plugin
    By inniss777 in forum Centrafuse
    Last Post: 11-24-2005, 03:56 PM
  2. Desperate for a ribbon extension cable
    By fabiolover2002 in forum General Hardware Discussion
    Last Post: 04-19-2005, 03:13 PM
  3. Cable Extension for PCI Slot- M10000
    By Tred in forum General Hardware Discussion
    Last Post: 11-21-2004, 10:08 PM
  4. FFS extension cable ghosting!! anyone use Belkin?
    By live2themaxuk in forum LCD/Display
    Last Post: 11-09-2004, 04:57 PM
  5. lcd cable length extension?
    By newbie in forum General Hardware Discussion
    Last Post: 03-13-2000, 06:31 PM
