Results 1 to 4 of 4
Thread: Mounting the BU-353
    Nov 2004
    South West
    Mounting the BU-353
    Mounting the BU-353
    Not as in trying to ride the thing but as in where to put it!
    As it is magnetic do you need to stick it to sheet metal (like a cb antenna) or not?
    Next, If not, do you need to mount it flat for it to work best?
    The simplest place for me to stick mine is on the back of some gauges that are ontop of the dash.
    So, i would be gluing it to a plastic cover, about 1" behind the windshield, 1" up from the top of the dash and it would be much the same angle as the glass (not sat flat like the top of the dash)
    It would have a 180deg view of the sky.
    Also, to get your direction (n/s/e/w) which part of the unit should point to the front of the car or will it only work out heading once you start moving?
    Thanks!
    PB 2.0Ghz, 20GB, 512mb, XPpro. 300GB Usb HDD, Griffin pwrmate, m-audio audiophile fw. BU-353 gps. 2x100w sony amps, 1x150w JBL sub amp, MBQuart front components, 6x9 rear, 10" sub. Audiocontrol epcienter, esp2, 3xs. Clifford G5, Finished, fitted, problems
    Variable Bitrate Fox_Mulder's Avatar
    Melbourne, Australia The Truth Is Out There
    I have mine flat on the dashboard:
    You can see a pic of it on this post
    [Aus] 2001 Toyota Avalon Vxi [Version. 2]
    On the back of those gauges should work fine, only way to know is to try it!
    Fox Mulder
    2004 Toyota MR2
    Modified Intel Xeon E5450 3Ghz Quad Core 2GB RAM 160GB SSD M4ATX Xenarc 700TSV TS Toslink Audio BU353 DiNovo Mini Car2PC ODBII Bluetooth HF 16x2 Character LCD
    Aug 2005
    Jersey
    I have mine in the back of the car on the inside, under the rear speaker deck cover, somewhere in the middle. No reception problems and you can't see it
    Maximum Bitrate seanz0rz's Avatar
    Jun 2005
    Cal Poly Pomona or Redlands, CA
    direction of the reciever doesnt matter, it tells your heading by comparing 2 data points.
    its magnetic so you COULD stick it to sheetmetal, not required tho.
    mine sits directly in the center of my dash, pushed all the way against the windshield
    1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Lifted, Locked, and Armored. CarPc in custom console with molded touchscreen.
    Pictures
    Photobucket is being updated, if a picture i posted no longer works, please PM me.
  1. Can't get the BU 353 to work with Destinator plugin
    By inniss777 in forum Centrafuse
    Last Post: 11-24-2005, 03:56 PM
  2. Mounting a 700tsv
    By ninjatill in forum LCD/Display
    Last Post: 10-07-2005, 12:47 PM
  3. Mounting amp and PC under seats?
    By omehegan in forum Fabrication
    Last Post: 08-21-2005, 04:21 PM
  4. How do I stick mounting tabs to a tinted rear windshield??
    By hd54321 in forum General MP3Car Discussion
    Last Post: 03-31-2005, 03:13 PM
  5. Methods of mounting?
    By MP3DUB in forum General Hardware Discussion
    Last Post: 10-01-2002, 06:40 PM
