Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
Thread: GPS mounting location
  1. #11
    May 2005
    I have used it (and another unit with my pocketPC) several times sitting on top of the dash, so there is no coating on the glass that can mess up the signal.. I wonder if the sound inculation under the dash has anything to do with it, although there is no metal or foil on it, just the padding...
    I don't want to leave it on the dash as that poses a theft risk, plus I would need to find a way of running the wire through to the USB hub behind the screen in the dash (no, not cutting a hole in the dash)
    Of course there is always bluetooth, but I can't afford to go that route at the moment unless there is a really good deal out there somewhere...
  2. #12
    Dec 2003
    Houston TX
    If you have a spoiler put it in there. Most spoilers are made of plastic. I dont know if that will interfear with it. I was thinking of putting mine inside my third brake light since i dont need.
    One question i havent been able to find is that if i extend the usb wire will it weaken the signal?
    *Laptop $107
    *Hauppauge WinTv-USB FM $36.02
    *USB Drive Enclosure $24.95
    *USB 2.0 PCMCIA Card $19.85
    *Crossover Cable $25.97
    *Earthmate GPS LT-20 $97.60
    *2.5 adapter 16.24
    Total - $327.63
    Current Budget - $322.37
    Aug 25. Deadline
  3. #13
    Oct 2004
    My Garmin GPS35PC is mounted on the rear deck, in the upper center tether (anchor) for child safety seat. The cable is routed into the trunk and extended to my laptop using CAT5 and DB9 to RJ45 adapters. The rear window has aftermarket tint however satellite reception is excellent. The vehicle is a 2004 Mazda 3 sedan.
  4. #14
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    Plastic should not interfere
    Quote Originally Posted by D M N
    I use a Bluetooth GPS placed INSIDE of the trunk and it works as good there as on the dash. My trunk lid is made of composite material (in other words, plastic.)
  5. #15
    Newbie reeva's Avatar
    Jan 2006
    Klerken [Belgium]
    mine is located on the center of the dashboard, I have about 5/6 satellites constantly ( also with my laptop for the moment, till I can afford a touchscreen )
    .:: Reeva.be ::.
    Just another personal site
  6. #16
    May 2005
    Can't put it in the spoiler - there is room but there is no way to get the cable back into the car without running it between the rear gate and weatherstripping.
    Wagon = no rear deck
  7. #17
    Variable Bitrate vxcarpc's Avatar
    Jan 2005
    Melbourne, Australia
    i have a magnetic one and i attach it to the roof behind the roof spoiler as i have a wagon. hides it so nobody can see it but still picks up almost 11 satelites.
    CAR INFO HERE
    "He who dies with the most toys, wins".
  8. #18
    Low Bitrate JackMan's Avatar
    Nov 2005
    Toronto, Ontario, Canada
    Quote Originally Posted by sebberry
    So basically your only option is to go the dash route then? I'd say hide it behind the window defroster vent so it isn't seen from the street, but it can still see the satalites through the vent? And seeing how you need to run it to the usb hub behind your screen, it would be like a foot away.
    Like in this car: ......Kinda.. lol
    For some reason, this is the only car I could find a pic of with a big old vent! lol, but you get the idea.. If you were to move it up to the defroster vents it would probably get zero signal loss, and have that stealth look you're after
    If not, you could always get an extension for the usb cable. I've heard others have had great experiences with them! (though some people have had awful ones) Good luck to you! Can't wait to see some pics when it's done
  9. #19
    Maximum Bitrate Civic03's Avatar
    Dec 2005
    I'm also interested to see how this turns out. I am also debating where mine will go!!
    PROGRESS 95%[//////////]Complete - Software configurations
    Current Task: Just adding on...
    Needed:wireless keyboard/mouse
    My Carputer Blog
    Car System Site
  10. #20
    Apr 2003
    Vancouver,bc, canada
    my gps receiver sits right under the sun roof glass, on top of the sun roof visor. .
  1. Replies: 91
    Last Post: 11-07-2006, 05:47 PM
  2. OEM GPS mod. Writeup + Pics
    By IntellaWorks in forum Hardware Development
    Last Post: 07-04-2006, 03:59 AM
  3. Tip GPS receiver location
    By justintime in forum GPS
    Last Post: 12-10-2005, 02:14 PM
  4. Window Tint's effect on GPS signal
    By MoFo in forum GPS
    Last Post: 07-19-2004, 06:08 PM
  5. GPS Mounting
    By Mxyzpltk in forum GPS
    Last Post: 10-06-2002, 10:38 AM
