Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Xport 3 problems
  1. #11
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    4800
    Lez, more widely known as flez1966
  2. #12
    Jun 2005
    So. Cal.
    I'm having problems with XPORT and standby/hibernation. The program works great for the most part; reconnects to the port, etc..; cept it crashes on resume like 95% of the time. I know it's meant for USB comports, but I'm using it on a bluetooth dongle with widcomm 1.4.2. I just don't understand why it crashes on resume. So any help to fix or to go about diagnosing the problem would be greatly appreciated.
    Thanks and excellent program btw.
    ps. I'm running RR, iGuidance, DLink BT w/widcomm 1.4.2
  3. #13
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by Chewster
    NOTHING to do with this thread. Dont thread-jack. ANd if port 9 is the correct port and there's data was coming from the gps you'd see a green dot by com9 and the NMEA data streaming at the bottom of the box. You need to test your gps without xport. Once ur sure its working properly then add xport back in.
  4. #14
    Jun 2005
    So. Cal.
    Well, the thread title is "Xport 3 problems" so I thought I'd report the problem in here also. Anyhow, my apologies...
  5. #15
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Well, that's exactly OT. I don't know what would be wrong with it though. Bluetooth should work, but XPort probably gets impatient with it since it takes a few seconds to connect. Do you know how long it usually takes? Like 5 or 10 seconds? And as far as crashing, can you give me an error code or anything?
  6. #16
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    I have been using XPort3 for 2 weeks now. Great program.
    Using it with my USB BR355 to help it out of hibernation.
    One thing though, since it enables us to use more than one GPS app, I decided to try to play with my spare GPS Rx I have lying around.
    I got some VB6 code to work with it, then I tried VS2005 using the .NET v2.0 Framework that has a new SerialPort Class.
    When I run the .NET serial port program with XPort3 and the .NET program uses the new SerialPort class it doesn't work. I then shutdown XPort3 and it works off the normal com port.
    If I use MSCOMM from VB6 in my .NET app, then it works fine by not using the new Serial Port class, but the old way...
    Weird. Also how hard would it be to add a Line to the GPS sentences. Cause some proprietary GPS send out sentences, and I wanna have my Old Co-Pilot 2003 work with my new BR355, but I noticed it's not spitting out this extra line that my other GPS does.
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
  7. #17
    Mar 2004
    Florence Yall, BFKY
    If you want to send me an app that uses the new serial port class, I'd be happy to take a look at what it's doing (or not doing). I could probably add some code for compatibility. Not sure about adding a fake sentence though.
  8. #18
    Super Moderator xBrady's Avatar
    USA
    Quote Originally Posted by LESLIEx317537
    What exception is being thrown when you try connecting using VB.net?
    Installed.
    -GPSSecure- - GPS Tracking
  1. Major Electrical Problems
    By techy101 in forum Off Topic
    Last Post: 07-11-2005, 10:47 AM
  2. DWW-700M/MTS12000 Motorized In Dash LCD Problems
    By techy101 in forum LCD/Display
    Last Post: 06-29-2005, 08:12 PM
  3. Audio problems, Epia Sound, and FAQ stuff
    By gothate in forum Newbie
    Last Post: 06-16-2005, 05:04 PM
  4. Dell Inspiron 8200 & Lilliput TS problems?
    By bkpsu in forum LCD/Display
    Last Post: 08-15-2004, 02:55 PM
  5. Replies: 13
    Last Post: 07-15-2004, 01:07 AM
