Results 1 to 10 of 18
Thread: Xport 3 problems
    Apr 2005
    Queens, New York
    Xport 3 problems
    OK wel i am trying to set up Xport3 with my GPS. I downloaded Xport 3 and the Compass. My GPS port prior to using Xport is Com9. I am trying to split the port into to.
    This is what my xport screen looks like:
    Now whenever i try to connect to comports 8 or 10 in iguidance nothing happens. And the compass, i set it to com 8, 10 and 9 but i get no data. Before i splitted the com ports the compas was reading data on com9
    How do i fix this?
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    has your gps moved from com9 ?
    I had it lose data because my usb/serial gps moved from 4 to 3
    Lez, more widely known as flez1966
    Apr 2005
    Queens, New York
    Nope it didnt move, in device manager is still stays com9
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    Jun 2002
    Virginia
    Check Curiosity's Xport threads. I remember reading that there's a problem with IGuidance when the com port has double digits. Since one of your ports is 10 that may well be the problem.
    Apr 2005
    Queens, New York
    Quote Originally Posted by kbreeden
    But the compass still does not get any data as well...
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    Jun 2002
    Virginia
    I've struggled with configuration of RR/IG/Xport myself, though I do have everything finally running properly. I don't know enough about it to help other than to mention that I do recall there being a problem with using double-digit com ports.
    Apr 2005
    Queens, New York
    ok well i switch all my com ports, input is on COM 2 and output is COM 6 and 7 but i get nothing still....
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    Apr 2005
    Queens, New York
    What should the baud rate be?
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Open hyper terminal and connect to the GPS COM port to see if you have data coming thru.
    If there is data coming thru, on the bottom of Xport windows, you will see the same type of data.
    BTW, just make sure that the GSP COM port works before you said it xport problem (it may have other problem but not this problem).
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Form the screenshot it looks like something is connected to COM9 so XPort can't access it. You will see a little green dot next to the input port like COM10 shows and see NMEA data at the bottom of the window when it's correctly connected to your GPS.
  1. Major Electrical Problems
    By techy101 in forum Off Topic
    Last Post: 07-11-2005, 10:47 AM
  2. DWW-700M/MTS12000 Motorized In Dash LCD Problems
    By techy101 in forum LCD/Display
    Last Post: 06-29-2005, 08:12 PM
  3. Audio problems, Epia Sound, and FAQ stuff
    By gothate in forum Newbie
    Last Post: 06-16-2005, 05:04 PM
  4. Dell Inspiron 8200 & Lilliput TS problems?
    By bkpsu in forum LCD/Display
    Last Post: 08-15-2004, 02:55 PM
  5. Replies: 13
    Last Post: 07-15-2004, 01:07 AM
