Results 1 to 7 of 7
Thread: GPSlim 236 Problems
    Apr 2005
    Queens, New York
    GPSlim 236 Problems
    Ok gusy so i finally completed my install today well for the most part. I booted the pc in the car everything loaded and was great. My GPS worked and everything. But then i shut down the PC, my sister came home and she wanted to see it so i started up and Next thing you know My GPSlim 236 becane an unknown device. There was a message saying that this device has malfunctioned and blah blah blah. But now when i plug the gps in i get no more unknown devices and it doesnt even acknowledge that i plugged it it. It is a usb connection. But all the light are working on the gps even the green light. But i get i was getting an unknow device but now i get nothing... i have no clue what the problem is. I dont understand why it was working fine when ui was conguring everything in my house and the first time i started the pc in the car. I dont know if it mite be the usb cable or what. But I tried plugging it into my friends comp and it didnt recognizr it as well, Can the usb cable just go bad like that?Can i pick up one of these usb cable at a local store??
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    FLAC Marvin Hlavac's Avatar
    May 2005
    I would try to:
    1. Unplug it from your PC
    2. Start > Settings > Control Pannel > System > Device Manager
    3. Look up the GPS receiver under "Ports"
    4. Right-click it > select Uninstall
    5. Restart PC
    6. (do NOT plug the GPS yet)
    7. Insert the CD that came with your GPSlim236
    8. Install the driver software
    9. Plug it in now
    10. If still no luck, plug it to another USB port
    The cable is really not just a cable, but it is a USB/Serial adapter, so you cannot use an ordinarry cable which has USB connector on one side and mini-USB on the other.
    Apr 2005
    Queens, New York
    Quote Originally Posted by Marvin Hlavac
    I would try to:
    But see here is the thing, it is not even listen under ports i already did that....I gotta go get the cd and try that. I downloaded the drivers from holux's website:
    http://www.holux.com.tw/Temp%20web/d...ta.html#GR-230 But it is just an .exe. I dont know if those are the exact drivers. But hopefully the cd will work!
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    Variable Bitrate ramy_zohair's Avatar
    Sharjah, Emirates
    I had this device, but gave it up for garmin. The usb cable that comes with the package is not for data. it is just for charging. you have to get the special usb cable if you want to connect it through usb, otherwise use bluetooth.
    "Together with the usual multi-country charger cable system and the ability to charge the battery from three different sources, this GPS continues its predeccesors success. Don't forget that this GPS can still be connected via both Bluetooth and a wired cable (available separately) simultaeneously."
    https://www1.securesiteserver.co.uk/...218edba5cd5693
    Hope this helps
    Apr 2005
    Queens, New York
    Quote Originally Posted by ramy_zohair
    Hope this helps
    The cable I am using at the moment is the one provided by HOLUX, but it doesnt seem to work when connecting to any computer anymore so i ordered a new cable.
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    May 2005
    I checked the link you provided, buy it didn't work. I found a driver (also exe) here: and I ran it on my home PC. It works. Try it to see what happens ;-)
    The (correct) cable desn't come in standard package. It is an optional cable which has to be ordered extra. It is about $19.
    The cable which is included with the standard package indeed will not work for your intended purpose. It is only good for charging (via USB).
    (...but you have said it worked for a while... so I'm confused what cable you really have...)
    Apr 2005
    Queens, New York
    I checked the link you provided, buy it didn't work. I found a driver (also exe) here: http://www.holux.com.tw/Temp%20web/download-data.html and I ran it on my home PC. It works. Try it to see what happens ;-)
    I have the $19 one. The serial to usb one
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
  1. Holux GPSlim 236 Help
    By ramy_zohair in forum GPS
    Last Post: 12-07-2005, 01:37 AM
  2. Still having XMPCR problems
    By rjoek in forum RR Bug Tracker
    Last Post: 09-23-2005, 02:08 PM
  3. DWW-700M/MTS12000 Motorized In Dash LCD Problems
    By techy101 in forum LCD/Display
    Last Post: 06-29-2005, 08:12 PM
  4. Audio problems, Epia Sound, and FAQ stuff
    By gothate in forum Newbie
    Last Post: 06-16-2005, 05:04 PM
  5. Dell Inspiron 8200 & Lilliput TS problems?
    By bkpsu in forum LCD/Display
    Last Post: 08-15-2004, 02:55 PM
