very cool. how much did it cost all up?
Well finally after way too long i've finished my dead reckoning set up.
The old thread that laidback did with his module is here. But I figured it was time for me to get my own thread.
But the project in a nutshell is that Ublox makes a dead reckoning module, but the problem is that it needs a carrier board to hold the TTL to RS-232 converter, backup battery and gyro. So I created one.
Also for those of you that want to know what dead reckoning is, basically by using speed pulses from your car and the onboard gyro, the GPS module can guess where you are going, so if you are driving around in a big city with lots of tall buildings, even if you lose GPS signal the module will still output your current speed and position. Yes it may not be as accurate, but will be much better than your position just stopping on the map where you lost signal.
I still need to install the module into a case and get it wired into the car. But so far as is good with it.
On to the pictures!
As you can see the carrier board is not much bigger than the module itself.
Also if anyone wants schematics and PCB layouts for the daughterboard they are more than welcome to them, just shoot me a PM.
肚子笑痛了
S60 Install
$330 roughly.
肚子笑痛了
S60 Install
nope it's just for looks.
it works as far as navigation goes, gonna test the DR portion of it tomorrow.
肚子笑痛了
S60 Install
cool. i expect detailled maps like uBlox and Tyco produce!
nah seriously, what about using a GPS logger and run a normal GPS reciever and the ublox. Do the journey a couple of times with the antenna on the ublox out in the open and then under something and then compare the coordinates at various points. Might be a bit too much work so maybe put some ASCII or delimited files on here for people to do the post processing for you. Can also use that software, forgotten what it was called, yo play back the log file into the GPS software for visual comparison.
actually with the U-center software that ublox makes I can load a image into it and it will trace my route into that image, so then I can just compare the two routes. For the most part I just need to drive and then disconnect the antenna, I should continue on the same path I was on regardless of a turn or not.
肚子笑痛了
S60 Install
Why does it have two serial ports![]()
