Results 1 to 10 of 20
Thread: whats the best antenna for behind the glass?
    Apr 2005
    I know the external antenns get better reception
    but whats the best antenna for behind the glass?
    I don't want to mount it externally because:
    1) don't wanna someone to rip it off (I live in NYC)
    2) drill through the top of the car
    thanks
    Newbie pasic's Avatar
    Nov 2005
    Canada
    i use the cheapest gps anteanna i could find and stuck it under the dash ... works just fine, will especially work through glass. they are all really the same. whenever i look it has atleast 5 satellites locked. one i have is called gps mouse , its about 50-70 bucks on ebay.
    Maximum Bitrate DJiK's Avatar
    Apr 2005
    Los Angeles (Winnetka), CA
    I used a Rikaline 6010 underneath the glass and it worked out very well...
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
    FLAC Marvin Hlavac's Avatar
    May 2005
    To have the "best" today, buy anything that adverizes "SirfStarIII chip included".
    Apr 2005
    thanks guys
    any of you live in a dense urban area too?
    I've talked to a few other drivers and they say they have problems with signals bouncing around?? in the city
    Low Bitrate JackMan's Avatar
    Nov 2005
    Toronto, Ontario, Canada
    Cool
    I have SirfStarIII like Marvin described in my reciever and I've never had problems with signals in the city, or even in the plane at 3,000 feet in a snowstorm (scary! But thanks to the GPS ) I have a BU-353 that is usb. works great. Good luck to you
    Jun 2004
    nyc
    Hello Black car. Good to see another New Yorker.
    I have my BU303 on the dash because of the same reason you're concerned with. It usually gets 3-4 SAT and maximum SAT I've ever got was 5 in the city with BU303 on the roof.
    Based on my experience is BU303 just doesn't cut it. SirfStarIII is said to be better.
    Hope this helps.
    Variable Bitrate nkotch's Avatar
    Dec 2005
    FL
    I've had no problems with my GPSslim236 (sirfStarIII) on the dash. I can actually put it just about anywhere in the car (on the seat, middle armrest ,etc.. and can still get a decent lock).
    Do you already have a GPS unit now and just looking for an antenna? Or are you looking at which GPS unit to get?
    If you don't have a usb GPS unit yet then get a simple gps unit w/ the sirstarIII chip and just hide it somewhere on the dash. If you just add a separate antenna and keep it inside the car you'll lose some signal because of coax losses (especially at those high frequencies).
    Nick
    '99 Ford Escort ZX2 CarPC <-- RIP Feb '07
    2006 Chevy Equinox LS (Current Project)
    **VIA EPIA PD 1ghz Mobo, OPUS 150, 7" LinITX LCD touchscreen, 512 Ram, 60Gig HD, DLink Bluetooth, Belkin 802.11g wireless,
    May 2005
    my bu-353 is mounted on the lower corner of my trucks rear window. Works wonderfully no matter how heavy the snow/rain/fog is.
    MS Streets and Trips '06 doesn't tell you how many satellites you're connected to (at least not that i know of), so I can't give that bit of info. But, a program I previously tried (which no longer works) said I locked 9 out of 12 satellites, while the truck was parked in my garage.
    Take 2 - '03 Audi A4
    macmini with an 8" widescreen (in progress)
    My 2004 Ford Ranger:
    14" LCD w/ custom made aluminum bezel
    Completly custom computer case
    status: Totaled
    Aug 2005
    S&T 06 doesn't give # of sats, blast them.
  1. Replies: 9
    Last Post: 04-22-2006, 09:22 AM
  2. Cable-less glass mount cellphone antenna?
    By b8bboi in forum Wireless Communications
    Last Post: 07-23-2005, 12:43 AM
  3. Power Antenna Control
    By fredp in forum General Hardware Discussion
    Last Post: 07-05-2005, 08:42 AM
  4. Through glass mount wifi antenna
    By n8scstm in forum General Hardware Discussion
    Last Post: 01-31-2005, 09:11 PM
  5. Cell Booster / Amplifier
    By GruvThang in forum General Hardware Discussion
    Last Post: 07-28-2004, 07:35 AM
