BR355 and iguidance
I have a few questions because i dont know if i am having a problem or not. My gps arrow doesn't move smooth across the screen it kinda of skips from point to point and when i come to a stop the gps thinks im changing directions so my screen starts spinning around. Is this normal or am i having problems?
Hm. Sounds weird, if it is spinning around..
I don't have any problems with the same setup !
I could sound like it's a bad connection to the sattelites. Or maybe some metal is interferring the signal! You could try to put the gps in the window as close to glass as possible, or even on the roof (not permanent, but to test)
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
