Results 1 to 10 of 11
Thread: USB GM-210 problems with a7n8x 2.0 deluxe
    Dec 2005
    So I've tested the Holux on 2 other PCs and the drivers provided on the holux uk website work fine and gps functionality seems to work correctly. However the carputer/wardriving pc I currently use is an a7n8x 2.0 deluxe. Drivers install fine and when I plug it in to any of the usb ports, xp recognizes it instantly and reports that it's ready to go. I then click scan with "gps viewer" which was supplied on the holux uk website and click scan. When it reaches the virtual COM that the usb is bridged to it stalls for a second, then displays "None" whereas on the other 2 pcs I tried it on have worked flawlessly. I've tried updating bios, MB drivers (USB as well), and switching to USB 1.1 in bios but still get the same result.
    I am posting with the hopes that someone else solved this problem with either the same gps or another brand, as google returned absolutely no results.
    Please, if you have any suggestions, post them and I'll be very grateful however useful they may be.
    I really wanna get started on my gps wigle mapping.
    Dec 2005
    looks like it's not going to work. have tried everything.
    My GPS receiver is USB. Does that mean I could just bypass the USB completely with a female usb to female serial port cable?
    Elsewhere
    Have you tried multiple USB ports?
    What you're experiencing is completely weird. My motherboard uses the same chipset (nForce2) and my GPS works flawlessly with it. Granted, I'm using a BU-353, but as far as drivers, they all use a serial-USB driver, sincve the GPS does nothing more than send raw data throught he serial bus.
    Perhaps reloading Windoze would fix whatever the problem is? It's a drastic step, but maybe something's pooched somewhere that we'll never find....
    How about the Wiki?
    Dec 2005
    Thanks!
    I tried all 6 usb ports. Same thing every time.
    I also tried popping a hard drive in from a computer where it works. Nothing.
    Constant Bitrate RawsonDR's Avatar
    Dec 2005
    Dayton, OH
    I stumbled across your thread on www.netstumbler.org and noticed you mention your BIOS serial port (1 and 2) settings. Have you tried disabling those (assuming you aren't using them)?
    Dec 2005
    heh. "I stumbled across your thread on www.netstumbler.org." oh the irony!
    Actually, I'm not sure if I have. I tried so many things it's hard to remember. I'll go try that again to make sure.
    Thanks.
    Do you happen to have the same gps receiver?
    Dec 2005
    Nope Didn't work. Same result.
    Constant Bitrate faichiu's Avatar
    are you using winxp? is it updated to SP2?
    98 Honda civic
    In-Dash LCD Monitor K-301
    cappuccino EZ3
    PIII-1.2GHZ
    256MB PC133
    40GB HD
    Holux GR 213 Sirf Star III GPS
    IguidanceV2
    CNX-P1900 power supply
    Sound Blaster Live USB
    Dec 2005
    Yes. Every update possible. Even tried putting the hard drive of computers in which it worked into this computer and got the same exact result.
    Dec 2005
    Dayton, OH
    Quote Originally Posted by dagnasty
    Nope, I have the same or similar motherboard though. I've used my BU-353 on it without problems.
    Have you messed around with device manager much? No errors in there? Maybe remove the device from device manager before you uninstall, reboot, and reinstall drivers.
    In device manager you can also check your IRQ's... see anything weird there? Are the USB host controllers sharing any IRQ's?
    Though now we're only stabbing at the dark. It should, of course, be working.
  1. Installing a USB Hub up-front? Read this...
    By hd54321 in forum General Hardware Discussion
    Last Post: 02-09-2007, 12:49 PM
  2. FS: 2-40gig 2.5" laptop HD in external USB 2.0 enclosure
    By riddle14 in forum Classified Archive
    Last Post: 03-19-2005, 11:41 AM
  3. USB 2.0 vs. Firewire... keeping a low profile
    By gregulator in forum General Hardware Discussion
    Last Post: 12-11-2003, 08:08 AM
  4. Storix External USB 2.0 DVD Review
    By VWTronics in forum Input Devices
    Last Post: 09-27-2003, 07:20 PM
  5. Replies: 7
    Last Post: 09-01-2002, 10:25 AM
