Results 1 to 10 of 16
Thread: GPS time zone sync
    Jan 2004
    Champaign, IL
    GPS time zone sync
    Has anyone tried software (preferably free and reliable) that will sync the Windows XP system clock with NMEA time output from GPS receiver?
    I'd appreciate any comments. Looking for something very simple that runs in the background. Thanks!
    Elsewhere
    I didn't know such software exists.
    Why would you even bother with this? Is your PC's clock not keeping accurate time? Is the on-by-default network time synchronization built into WindowsXP not accurate enough?
    How about the Wiki?
    Jan 2004
    Champaign, IL
    When I change time zones I need to update the time as such. And I don't typically use NTP in my car computer. I don't care so much about the accuracy of the time (to the minute/second) as I do about the hour.
    I should have been more clear: what I really want to do is change the time zone, not the hour.
    Look at http://www.topshareware.com/GPS-Time...load-39576.htm (first result from a Google search)
    Elsewhere
    Ahhh. I misunderstood.
    Again, I didn't know such software existed, but it certainly seems like a good idea if you drive cross-country a lot.
    How about the Wiki?
    Maximum Bitrate wi77iam's Avatar
    Jun 2003
    Chester Springs, PA
    This should be fairly easy to do. Just grab the time from the nmea string and use it to set the system time. I'll give it a go if I find some free time (no pun intended).
    FLAC Marvin Hlavac's Avatar
    May 2005
    Time can be synchronized with NMEA Time ( ), but I'm afraid they forgot to include the time zone synchronization (perhaps you could request a new feature ;-)
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    IIRC dragonbtv created software like this.
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Is there a list of coordinates for each timezone somewhere on the net that could be used to do this?
    Jan 2004
    Champaign, IL
    Thanks for the comments. Did some looking, and the share(free)ware stuff out there can also use GPZDA, which allows time zone sync, but this string is not commonly output for consumer USB GPS devices, such as my Rayming TN-200. Looks like there are a few that do but I would need to buy a new one.
    A database of timezone coordinates is therefore not needed, unless the more common output is used. Might be more complicated though? Is there an easy way to sync the time zone using just GPGGA?
    Mar 2004
    Florence Yall, BFKY
    GGA just has UTC (GMT) time, so it's the same everywhere. It's very easy to use since SetSystemTime() can take it without conversion. I do that in my compass app. I'm not even sure that you can set the timezone programatically. It would be nice though.
  1. Replies: 11
    Last Post: 01-31-2006, 04:37 AM
  2. My GPS scenario & Bluetooth quest.
    By gizak in forum GPS
    Last Post: 04-12-2005, 01:11 PM
  3. Delorme Street Atlas 05 quick review
    By cash_Money in forum GPS
    Last Post: 12-13-2004, 08:31 PM
  4. D3 with USB GPS after HIBERNATION
    By BOND007BE in forum Map Monkey
    Last Post: 11-26-2004, 02:54 PM
  5. gps tripmate position time?
    By schrodos in forum General Hardware Discussion
    Last Post: 11-29-2000, 02:21 AM
