Results 1 to 7 of 7
Thread: Experience with the MP3car GPS antenna
    May 2005
    Has anyone used this antenna?
    http://www.mp3car.com/store/product_...roducts_id=148
    Just wondering how easy the install is and what the accuracy/quality of reception is like.
    Thanks!
    May 2005
    Nevermind, I just noticed there is no USB connection on this one
    Any other similar products you can recommend?
    Elsewhere
    I think you figured out that that Hirschmann model is just an antenna.
    Are you looking for a GPS receiver? Try the BU-353.
    How about the Wiki?
    Newbie Smokemaximus's Avatar
    Dec 2005
    TX
    delorme earthmate lt-20 reciever is pretty good. I use it with my set-up. Its usb. But to use it for iguidance you need the delorme usb to serial driver.
    May 2005
    I have a Microsoft receiver (a re-branded pharos) but it doesn't get a strong enough of a signal under my dash. I suppose I can just get by with mounting it on top of the dash, but then there is the unsightly USB cable.
    There is a perfect spot to mount my antenna - the rear wing on my wagon, however I can't get the USB connector through the rubber hose where the antenna and 3rd brake light connector is...
    Hmmm.. back to the drawing board.
    Victoria, TX
    I have this antenna installed on my truck and it works great for gps and wireless.
    I used an Axiom GPS module inside my case with this antenna.
    http://www.allsurplus.net/Axiom/
    No cell phone so haven't tested that part yet.
    Install does mean drilling a 3/4" hole in the roof, but this is a standard roof mount antenna size - so just about any decent install shop has a shallow antenna holesaw just for this purpose.
    Once the hole is drilled, drop the wires through and bolt up from underneath.
    Then you just get pigtails from FME-male to whatever your equipment has.
    _
    Mar 2004
    Little Elm, Texas
    Mr_Wizard - how is the reception strength with this antenna?
    do we know anything about the GPS antenna that's in it?
    also, how would I go about utilizing the Callular portion of that?
    Jan Bennett
  1. Replies: 65
    Last Post: 10-13-2009, 07:51 PM
  2. OEM GPS mod. Writeup + Pics
    By IntellaWorks in forum Hardware Development
    Last Post: 07-04-2006, 03:59 AM
  3. Replies: 11
    Last Post: 12-06-2004, 04:48 PM
  4. GPS + FM antenna replacement...
    By paperinics in forum GPS
    Last Post: 10-11-2004, 02:08 PM
  5. Gps Module + External Antenna + Waas + Usb
    By e_z_street in forum GPS
    Last Post: 10-06-2004, 04:57 PM
