it will run, but you won't be able use the direction arrow and see the map at the same time
will this run with the screen resolution set to be able to use the PS1 screen as a display? or if will not does anyone have any suggestions as to a software that will run with the PS1 screen
Causa latet vis est notissima
VIA SP13000
1GB DDR400
Slimline Slot-load DVD-RW
60GB 2.5 Inch SATA 5400RPM
Dual Active PCI riser
PCI TV/FM card
Logisys FP800
Thermaltake VFD Media Lab
M1-ATX
