Thanks for your advise. Are you sure the placement of the antenna is ok, try moving it around. Seems unlike that DeLorme would sell a unit that does not work. Maybe try different locations???
Do not buy this POS GPS reciever. Just came back from a trip and this thing is the most unreliable POS I have seen. Granted I havent had anything else but Just when I needed it the most it loses signal. Right before I would need to turn it would lose Sats and then I would be like WTF!. Luckily I had a trusty old fashion paper map. I need the most reliable dash mount antenna thats out there. I hear the Sirf star iii sp? Is pretty good. Please advise. Also I drive a 2005 nissan maxima. My guidance was Iguidance 2.1.3 and also delorme 2006. Delorme 2006 sucks as well. Advice is appreciated![]()
AtmosUSA.biz, E-Cig Mods
"A great smoking alternative"
I have had no issues with the signal quality using my LT-20. I have my unit located on the reardeck. Where is yours located?Originally Posted by Smokemaximus
edit
I have 20% tints covering my rear glass.
Check out my install pics; http://mp3car.com/vbulletin/showthread.php?t=70842
The LT-20 is NOT the same as the old Earthmate USB (now sale as pro).
And I have to agree that it is SUCK compare to the "pro".
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
I agree. I have one of these in one of my vehicles, a Rikaline 6010 in the other, and the Rikaline ****es on this hunk of crap. And the Delorme software still shows street/highway names that are at least ten years out of date for my area.
the LT-20 is horrible. the drivers arent bad though, built in com splitter and decent monitors, still no need. also, bright yellow?
I have tried different areas on the front window. My rear is metalized tint So I cant put it on the rear shelf. I works great sitting still but start moving then its a whole different story. Takes too long to acquire new sats.Originally Posted by muldrick
i'm using mine okie,
it's still okie
Progress Bar: [//////////]100%
Have M10000, 40gb 2.5"hdd, i guidance, wireless,slim slot drive, delorme gps, roadrunner, liliput touchscreen, opus150w ...
all fabrication done...
wow, can't believe i'm hearing this. i've had this receiver w/iguidance work flawlessly for over 6 months now.
took it from VA ---> PA and back with no problems (even through PA's mountains)
i have mine on my rear deck w/35% tint.
only problem i have is sometimes when boot from being on hibernate, the computer doesn't recognize the receiver, i simply have to restart, and the problem is fixed.
to op: must be something wrong with your setup. hopefully you figure it out.
No the led constantlly blinks red. I will be driving along and boom it loses sats, weither im driving straight or turning. POS.Originally Posted by fventura03
