Solved my problem of getting MapMonkey to recognize BT GPSlim 236, after doing some additional searching under the GPS Forum.
Peformed the following to attain the solution, provided below as FYI:
- Ran BT Manager and paired BT GPS to Serial Port Profile and connected service to BT GPS which assigned COM4 to BT GPS
- Ran GPSgate and set input port to COM4 and create virtual ports for COM 14, 15 and 16 (lower ports were not available in GPSgate).
- Edited Settings.ini in MapMonkey directory and assigned Adv Settings COM Port to COM 14, Saved Setting.ini file.
- Open MapMonkey and immediately recognized BT GPSlim 236
Hope this help others, because it took a while to figure out
LinkBack URL
About LinkBacks
