Results 1 to 7 of 7
Thread: Help: System Hibernation Failed because of COM1 (GPS)?
    Maximum Bitrate srcstc's Avatar
    Dec 2003
    New Jersey
    Every time I try to go to hibernation I get this error. My GlobalSat BR-355 is on COM1. Anyone know a fix?
    -Rich
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    use hybernate trigger and write a script to dissable com 1 via microsofts devcon, on the way back up use another script to enable it again. Has worked for me for months now although I have done it via an autoit exe instead of a bat file but it will work either way.
    Dec 2003
    New Jersey
    Quote Originally Posted by v8 scimitar
    So you had this same Problem? Why does it happen?
    BTW, I switched to the other COM port and it hasn't done it since.
    Rich
    Jan 2005
    Scotland
    Well I am assuming your GPS is USB and win XP is well known for having problems with USB devices in hybernation. One machine I have has no problems and another has but it is exactly the same GPS reciver as in the same one not just same model. Anyway the script sorts it out and is completely transparent.
    Dec 2003
    New Jersey
    It's serial, not USB.
    Jan 2005
    Scotland
    I should have actually realised it was serial being on com 1. I think my solution will still work for you although it isnt the usual problem. I assume you do actually have the latest drivers? You arent sharing it through a com splitter or anything are you?
    Dec 2003
    New Jersey
    I didn't install any driver's cause it's serial. It's been working fine on COM2 though.
    Rich
  1. System error skin and mapmonkey gps ?
    By tony_vodka in forum Software & Software Development
    Last Post: 02-18-2006, 02:52 PM
  2. possible gps system?
    By kozman31 in forum GPS
    Last Post: 03-27-2003, 04:24 AM
  3. Replies: 7
    Last Post: 10-13-2002, 08:57 PM
  4. GPS software similar to Mercedes system?
    By Phat Justice in forum Software & Software Development
    Last Post: 08-10-2000, 07:26 PM
  5. $60 GPS System! Antenna and software!
    By lifter in forum General Hardware Discussion
    Last Post: 07-19-2000, 08:22 PM
