because i know all the info am about to give you is inside this forum coz i had the same issue with that GPS!!!
but here is what you can do:
1st to let you know if it's cloudy chance are you'll not get a fix.
okay , what you can do is to open the case of the gps, inside you'll see a cap,some ppl like to call it "watch bat" coz it does look like one...any ways de-solider this cap and put back your gps, that should fix it for you, if not then it's a defect with the GPS.
Also did you mention that your gps is an RS232 and you are using one of those USB>COM convertor...that could be your problem right there..
LinkBack URL
About LinkBacks
