Have you tried it on windows mobile 2003? it may be worth a try. I was gonna try it but dont have much time.Originally Posted by Custom
The emulator is buggy.![]()
Originally Posted by Chris31
Well i tried it on a IBM P4 3.2 ghz with 512 mb RAM and still same problems with sound and from time to time with "Storage Card", it seems that sometimes the Emulator have problems reading data from "Storage Card"
If someone manage to make iGO work normal on a Emulator i would be happy to see how he did it.
Can someone explain how to install the Emulator and how to connect it to iGo.
I'm from Israel and i would like to try it on PC.
On my laptop it's work properly. Now I'm working on VGA icons to get better display. Emulator works maximum 640x640x16, but it's sure enough for a Liliput.
Magyaroknak: http://rigya.atw.hu
i-go works on my PPC perfect. My oppinion is that is much better than TomTom which I was using before. I hope I'll get my touchscreen today from service, so I'll be able to try it on carpc.
Hi, I'm trying to install iGO 2006 on my laptop. Since I have no internal card reader, but only a bulky external USB one (which adds to the difficulty to carry all the devices), I'm trying to copy the files from the original SD on the hard disk. I'm using Microsoft Device Emulation 2.0 with the Windows Mobile 5.0 image. All I can get is a "Failed to identify SD card" message. Any suggestions?
I am surprised, how exactly did you made it work perfectly on a PC ?
Can you give us details (step by step if possible)
I just finished my project and would like to install iGO as a navigation software.
Does anyone have higher resolution files for iGo?
I have iGo running on a Windows CE 8.4" tablet in 800x600 resolution, but the max I can get iGo to display at is 320x480, looks very tacky on such a big screen.
Apparently I need the "data.zip" UI files in a higher resolution, anyone have any higher?
It seems it does not work on high resolution. Everything working okay on your emulator ? I mean the igo sound plays corectly ? because when i run iGO on the emulator the sound doesnt looks good, i mean it makes pauses.
Mines not running on an emulator, I am running it on a Win CE .Net 4.2 tablet.
I am sure the UI files can be tweaked... do you know if anyones tried? .. I will try myself but didnt want to waste time trying if someone knows it wont work.
