Results 1 to 4 of 4
Thread: New GPS module is sensitive enough to be used indoors
    Apr 2006
    Indiana
    Very interesting new product for our application. Hopefully this will be out in a couple months when I do a new build.
    http://www.tgdaily.com/2006/04/19/navman_gps_jupiter30/
    FLAC Marvin Hlavac's Avatar
    May 2005
    Based on the specifications revealed in the article: "Capable of detecting signals as weak as -159 dBM", and "It can track up to 20 GPS satellites simultaneously" it appears the module will be based on the not-so-new-anymore SiRFstarIII chipset.
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    肚子笑痛了
    S60 Install
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    Yep, SiRF-III works well inside the house. It doesn't work so well inside a metal car though.
    Does anyone know of a USB SiRF-III reciever that has an antenna connector? I have a BT one, but it turns itself off all the time and you have to press the power button to get it on again (even when charging from USB). I found a CF one with connector that I will probably use, but USB would be better.
    I'd also love to see a SiRF-III with DR.
  1. Ublox Dead Reckoning GPS
    By jcdillin in forum GPS
    Last Post: 09-10-2014, 12:00 PM
  2. Getting Started with GPS
    By grepzen in forum The FAQ Emporium
    Last Post: 09-26-2006, 05:54 AM
  3. OEM GPS Modules.
    By IntellaWorks in forum Hardware Development
    Last Post: 03-08-2005, 06:29 AM
  4. Newbie's guide
    By EBFoxbat in forum Newbie
    Last Post: 02-08-2005, 10:06 AM
  5. Window Tint's effect on GPS signal
    By MoFo in forum GPS
    Last Post: 07-19-2004, 05:08 PM
