Results 1 to 7 of 7
Thread: What software has Multiple Stops Logistics Routing?
    Constant Bitrate bridqer's Avatar
    Nov 2003
    Maryland/Arizona
    You know, the fastest order to do things in.
    I use CarPC's in my trucks primarily for navigation, I cover three states and average 1000mi a week. I make 3-10 stops a day. I don't make any money while driving so it is important to me to spend the least amount of time driving.
    I currently Use Copilot 9 for that reason. I can enter multiple stops, move my final destination to the bottom of the list, and select "optimize." It plots the fastest route from my current location, through all stops to my final destination. I like that I don't have to "plan" a trip, choose my start point, save the trip file, use it as my route.
    Only the map data is sometimes inaccurate, might be a problem in all software, also I have been interested in trying some more frontend integrated nav software. So I am curious to know what other software would work for me.
    I am pimarily interested in Iguidance and Streetdeck
    The only other software I have used is Streetatlas+ 2003
    '99 F-350 Crew 7.3L~'02 F-350 Crew 7.3L~ '04 Dakota SLT+ 4.7L
    MII12000opus120~MII12000opus120~MII10000opus150
    NA~Senao dual 7.4 ant~Orinoco Gold
    Pioneer~Pioneer~PG Octane-R R5.1MT
    Xenarc, Rikaline6010, Garmin OEM16 HVS, CoPilot10
    Apr 2006
    Dallas, TX
    I use Microsoft Streets & Trips 2006 and it works pretty good for me. It seems to be doing what you need it to do as well. Put in all your stops, final destination and click on the plan my route button and it gives you 3 choices of traveling. I think they are like shortest, fastest, no highways? or something similar. If you put in how many miles per gallons your car gets, it'll even recommend when to pull over to pump gas as well!
    Variable Bitrate nkotch's Avatar
    Dec 2005
    FL
    Just an FYI - iguidance won't do that. Currently use it in my car and I think that it'll only let you do one "stopover" in your route.
    You could also look into the newest Delorme Street Atlas (2006 I think), I've got it installed on another computer so I'll have to take a look and see if it can do that.
    One problem you may run into is that some nav programs that are designed to be easy to use in a car/integrated environment don't have all the fancy features that some of the other nav programs do that are a little more "involved" to use in a car environment.
    Nick
    '99 Ford Escort ZX2 CarPC <-- RIP Feb '07
    2006 Chevy Equinox LS (Current Project)
    **VIA EPIA PD 1ghz Mobo, OPUS 150, 7" LinITX LCD touchscreen, 512 Ram, 60Gig HD, DLink Bluetooth, Belkin 802.11g wireless,
    Elsewhere
    CoPilot is/was one of the most sophisticated Nav programs around.
    How do you do a 'stopover' in iGuidance? I haven't figured that one out yet...
    How about the Wiki?
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by DarquePervert
    Once you have a route enter.
    Menu->Destination->Stopover.
    OP: MS S&T2006 does allow multiple stopovers. It's a very good trip planner software, but not a good nav software.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Nov 2003
    Maryland/Arizona
    Thanks all. I will just stick with copilot, it seems to do what I want best. I just wish I could synch the custom POI between my trucks. Copilot 9 now allows importing ov2 files, but has no way of exporting. Maybe next version.
    FLAC is for flaccid parksgm's Avatar
    Dec 2005
    Dallas, Texas
    Bridqer, it sounds like you've used CoPilot for a while...and I noticed that you've used Version 8 as well.
    Did you notice any significant improvement in the quality of the map data between versions 8 and 9? What about POIs? I have version 8, and am frustrated by the lack of/missing POI information and sometime inaccurate map data.
    Thanks,
    Gregory
  1. Suggestion for the Software forum
    By Confused in forum Mp3car Forum Suggestions/Comments
    Last Post: 11-02-2004, 08:55 AM
  2. myHTPC Software
    By the_new_guy in forum Software & Software Development
    Last Post: 06-05-2004, 04:51 PM
  3. what routing software for Europe
    By felix99 in forum GPS
    Last Post: 11-24-2002, 09:52 AM
  4. keypad software supporting multiple playlists
    By minnow255 in forum Software & Software Development
    Last Post: 09-11-2000, 03:46 PM
