sounds like an issue with USB and hibernation. Do you have it connected to a USB hub? Is that hub powered? Do other USB devices have issues after coming out of hibernation? I have seen a lot of other posts with similar USB issues, most seem to stem from the power management settings for the USB. Check the "power management" tab on the USB root properties in device manager. Is it set to "allow the computer to turn off this device to save power"? Hope some of this helps...
LinkBack URL
About LinkBacks
