Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 43
Thread: Price of GPS?
  1. #11
    Jun 2006
    Im looking round for similar at the moment. Not found any good value for money gps software really. Had a look into destinator, but it doesnt look very good. And its damn hard to find the SDK from legal sources, let alone if you wanted to electronically aquire it! Having a look at Navgion 5 but still not found any kind of trial to see if i like it, although version 6 does look good
  2. #12
    Maximum Bitrate LiquidKernel's Avatar
    Feb 2005
    Quote Originally Posted by Maheriano
    That one looks like it needs a power supply other than the USB cable. Am I right?
    Or is this the one you mean?
    Yep, the one with just USB. The Holux 213 model (no PS/2 connector or anything). Works amazingly well.
    Yes, it works with MS S&T (tested and works) and with Routis/iGuidance (also tested and works, iGuidance is what I use).. it's just a standard NMEA receiver.
  3. #13
    May 2006
    Calgary, Alberta
    So I guess all I need is a reason not to buy it. Is there anything at all I'm going to realize once I get it and regret? Anything at all this thing doesn't do that some other one might? No downsides?
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  4. #14
    Feb 2005
    I know for a fact that it doesn't have an external antenna connector, but you can always add that if you wish. However, it is a strong receiver, so I doubt you'll need to. Check around, some people have said great things about it. I'm just glad it works well and I have 0 issues with it.
  5. #15
    May 2006
    Calgary, Alberta
    Wow, that's something I didn't come across in my research. Why would I need an external antenna? I guess if you haven't had any problems with just the receiver itself picking up a satellite, it wouldn't matter much. Where do you have yours mounted?
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  6. #16
    Feb 2005
    Rear deck (hat shelf), works fine.
  7. #17
    Elsewhere
    My BU353 sits on my dash presently. When I get down to the final install, it will be inside the dash under the plastic, sitting on the center console air vents. There's only one layer of plastic above the GPS, so I shouldn't have any problems getting a lock, nor any visible GPS for a thief to try to steal.
    How about the Wiki?
  8. #18
    May 2006
    Calgary, Alberta
    It would work with something in the way like that?
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  9. #19
    Feb 2005
    All GPS devices or antennas are enclosed in plastic... another layer won't hurt it.
  10. #20
    May 2006
    Calgary, Alberta
    Nice, I'll pick up the Holux, thanks. Continue to post though if anyone knows why I shouldn't.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  1. Replies: 11
    Last Post: 01-31-2006, 04:37 AM
  2. How do I setup my GPS Application ?
    By guino in forum RR FAQ
    Last Post: 03-20-2005, 03:17 PM
  3. price of UK gps software....
    By m2rv h in forum GPS
    Last Post: 06-08-2004, 04:40 AM
