Results 1 to 10 of 11
Thread: Difference in iGuidance versions??
    May 2006
    I have 2.1 NA and I'm thinking of upgrading to 2.1.3 NA, but what are the differences between the two versions?
    FLAC ukchris's Avatar
    Nov 2003
    Massachusetts
    I got 2.1.3 and didn't really notice a difference, the update is only 18mb so it can't make significanyt map changes.
    May 2006
    Quote Originally Posted by ukchris
    Well if it isn't changing any map data...which I'm sure it's not...then the 18mb must just be of programming changes....and 18mb of programming changes could be a lot...so I was curious what was changed.
    Elsewhere
    How about the Wiki?
    May 2006
    Quote Originally Posted by DarquePervert
    that lists 2.1, 2.1.1, 2.1.2 and 2.1.3 as all the same, which they're not, so that doesnt help.
    May 2005
    Vienna, VA
    If you can get the upgrade for free from iNav (which they did offer a couple of months ago), of course, go for it. Otherwise, I suggest you wait until the next major version, which is supposedly much better and geared more towards laptops.
    iGMon - Integration between iGuidance and Road Runner
    CFX - Skin for Road Runner
    May 2006
    any word on when the next major version is due?
    Aug 2005
    I do know some of the mod software developed on this forum won't work with the newer 2.1.3 .exe
    The Lavender Tie Just
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    I asked Inavcorp in an email for the differences in the versions. Here's what I got as a response....
    Assuming what you have is v2.1:
    v2.1.1
    -deleted the multiple city zone listing so when you look up a city center or POI, listings no longer separated into multiple zones.
    -corrected Maploader issue w/ TX & CA
    v2.1.2:
    -corrected "off road" error
    -corrected missing El Paso, TX map
    v2.1.3:
    -added wm5 support (but no longer support ppc2002)
    -corrected contact lookup issue
    All the above information may also be found on our website www.inavcorp.com under news/announcements section as well as support > download section.
    Thank you.
    Support Team
    Nov 2003
    Massachusetts
    Interesting, when I installed the 2.1.3 update it didn't prompt me to upadte my PDA, then again when I later installed on my phone it does work under WM5 and works well in landscape so maybe they snuck an update in without me noticing.
  1. Replies: 570
    Last Post: 11-05-2009, 03:49 PM
  2. Replies: 17
    Last Post: 06-15-2006, 01:46 AM
  3. iGuidance Font Size Fix summary thread
    By Viscouse in forum GPS
    Last Post: 03-28-2006, 07:21 PM
  4. Iguidance 2.1.3 difference from 2.1.1?
    By sebberry in forum GPS
    Last Post: 03-13-2006, 03:13 PM
  5. Hacking Iguidance
    By Peoples in forum GPS
    Last Post: 08-28-2005, 07:40 PM
