Results 11 to 20 of 24
Thread: iGuidance smooth driving ideas
  1. #11
    May 2005
    Vienna, VA
    all I need is to delay the signal for 1 second
    I don't think this is a good idea. I believe the GPS signal already lags behind 1 second as is.
    iGMon - Integration between iGuidance and Road Runner
    CFX - Skin for Road Runner
  2. #12
    Jun 2006
    Quote Originally Posted by b8bboi
    The NMEA position line that gets written out to the serial port is < 1 second old because it updates every second.
    purdoom, I would imagine your idea would work just fine. It'd go something like this:
    • Remember the last GPS point
    • When the most current GPS point comes in, "draw a line" between the two points
    • Pick 6 points on that line, feed them to the fake COM port every 1/6th of a second
    • Set the most current GPS point to the last GPS point and start over
  3. #13
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by YellowBkpk
    The problem isn't ther NMEA sentence from the GPS, the problem is that IG probably only updates every second, and not when you send a sentance to it, but of course you/they can try. Ther other issue is can you send a sentence in 1/6 of a second.
    Michal
  4. #14
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Wiredwrx
    The problem isn't ther NMEA sentence from the GPS, the problem is that IG probably only updates every second, and not when you send a sentance to it, but of course you/they can try. Ther other issue is can you send a sentence in w/f of a second.
    Michal
    So then how come yhou can pick a baud rate in iG?
  5. #15
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by 0l33l
    I thought the baud rate is just the speed the sentence is sent, not how often it is sent.
    Perhaps you can get the whole sentence out in 1/6 of a second, but I don't think the SW will update that quickly.
    I may be wrong.
    Michael
  6. #16
    FLAC Marvin Hlavac's Avatar
    May 2005
    I just sent a quick e-mail to Garmin, the maker of GPS18-5Hz receiver. I asked if any of their GPS car navigation software, or any other software currently on the market, would actually refresh map on the screen 5 times per second in cunjunction with their GPS18-5Hz receiver.
    I think the answer will be a no.
    When (or if) I receive a reply I will post here.
    More info on GPS 18-5Hz receiver:
    "The GPS 18 5Hz is a GPS sensor targeted to OEM clients for use in machine control, guidance, and various agricultural applications where 5 Hz position and velocity reports from a small, highly accurate GPS receiver are required."
  7. #17
    Registered User
    May 2003
    Increasing the baudrate have no effect on the position update rate.
    Its just increases the speed of the "set of sentences" is sent to the comport. Try it, you see that the "set of sentence" is sent at a burst at 1 set per seconds.
    $GPRMC is the most important sentence in the set as this contains the position, you see that this only get sent once every second no matter how fast the baudrate is.
  8. #18
    May 2005
    25 minutes after asking, here is the answer:
    Dear Marvin,
    Our mapping applications generally refresh the screen once per record (which
    is generally once per second) and those records are generally set to go at a
    9600 baud rate. If you look at the output of the GPS 18 5Hz in Garmin
    binary mode, it can't keep up at 9600 baud, so there would be missing
    records. It's possible to increase the baud rate, but our mapping programs
    have not been designed to adjust the baud rate of the attached receiver, so
    our mapping programs would only render a screen for each record that
    actually made it through the serial interface. I suppose that you might
    expect roughly 3 out of 5 records to make it through due to bandwidth
    limitations imposed by the use of 9600 baud on the serial port.
    If 5 Hz becomes a common report rate for our receivers, then I would expect
    a future version of nRoute to allow configuration for using a higher baud
    rate on the serial port.
    Regards,
    XXXX XXXXXX
  9. #19
    Registered User
    May 2003
    To those who want to play with this 5Hz update rate, you can try to pump more $GPRMC sentence into the GPS apps per seconds by using some terminal program. I know some apps expect the 1 per sec update rate, if not then it would say GPS not found.
    I have never tried pumping more $GPRMC into the apps per seconds but I wont be to confident it would work.
  10. #20
    FLAC PURDooM's Avatar
    Jun 2005
    Anoka County, MN
    Quote Originally Posted by Chris31
    But thats the idea, if you bump up the virtual com port speed couldn't you send 10 $GPRMC strings per second? Its not an issue of if the gps can do it, its all about if your software gps simulator can do it.
    Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
    Unlimited Internet and gps tracking for $6 a month with boost mobile!
    Carputer 2: www.lmaocar.com
  1. iGuidance SDK
    By Quattro in forum GPS
    Last Post: 06-23-2006, 08:37 AM
  2. Iguidance sticky clutter removal ideas
    By Viscouse in forum Mp3car Forum Suggestions/Comments
    Last Post: 09-01-2005, 07:07 PM
  3. Road Runner sceen for iguidance
    By Kalt in forum RR Skins
    Last Post: 05-16-2005, 12:42 PM
  4. iGuidance or Rand McNally
    By SouL-FoRTuNe in forum GPS
    Last Post: 05-04-2005, 10:01 PM
  5. IGuidance 2.0... WOW
    By unsavory in forum GPS
    Last Post: 04-20-2005, 02:14 AM
