I believe you problem is with the "Please make sure you have your GPS device COnnected" Try putting you GPS device in and have iguidance read its port upon load and then try it.... Second, dont use Igmon with iglaunch
I'm trying to figure this out as I go and after a day of reading and testing, I think it's time to ask some questions. I have Road Runner working perfect and iGuidance working perfect. For some reason I'm unable to put the two together. I ran IGMON, both beta and non beta, with both iGuidance and IGLAUNCH, but still can't get it. So here we go.
I open RoadRunner and get this.
Then I click OK and get this.
After lots of troubleshooting, I realized I could right click RoadRunner on the task bar, minimize it, and I get this.
So I click the restore button to bring it up and get this.
And finally, when I restore RoadRunner, I get this.
So that's just part 1. Now we click the 4 arrows on the bottom of the navigation window and get this.
I click OK and it gives me this.
I click OK again and get this.
Now, I do have Windows set to open new browser windows as new instances but I don't think that would have anything to do with this. Or would it? Also, it appears to be changing songs everytime I click on something here, how is that?
Ampie Case
256 MB DDR2 PC5400
Xenarc 700TSV - VGA Monitor
Intel D945GCLF Motherboard
M2-ATX-HV
2005 Honda Civic
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
Sorry, I don't get it. My GPS is always connected on port 3, how do I get iGuidance to read it upon load?Originally Posted by Cheekz185
I already ran IGMON, is there a way to unrun it?
Ampie Case
256 MB DDR2 PC5400
M2-ATX-HV
2005 Honda Civic
In iGuidance go to "Tool" go down to GPS Options and then go to COM Port and then make sure that Com 3 is selected
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
I think gpsgate has the ability to deliver dummy data to iGuidance while the real gps is loading. What you are seeing is a symptom of USB gps recievers comming out of hibernation.
Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
Unlimited Internet and gps tracking for $6 a month with boost mobile!
Carputer 2: www.lmaocar.com
It already is selected.Originally Posted by Cheekz185
Ampie Case
256 MB DDR2 PC5400
M2-ATX-HV
2005 Honda Civic
Damn, I changed the Road Runner external GPS link from Skinbedder to IGLaunch, reinstalled iGuidance and pow!
But when I hit the 4 arrows, I'm still getting this ****. Why does it load iGuidance outside Road Runner? Even if I close Road Runner at this point, iGuidance stays open.
Also, the button sizes changed, how do I change them back? I saw a big button mod but I don't remember doing that. And I heard it doesn't work for iGuidance 2.1.3. I don't know, somehow I had bigger buttons.
Ampie Case
256 MB DDR2 PC5400
M2-ATX-HV
2005 Honda Civic
yeah I too had problems with getting IG to run in RR. I just gave up.....yeah I'm lazy and hoping that a better alternative will come along.
iGLaunch won't work if you don't have the GPS receiver hooked up. Here's a hint: run iG with the |nowarning.
The receiver is hooked up. And how do I run the |nowarning command?Originally Posted by 0l33l
Ampie Case
256 MB DDR2 PC5400
M2-ATX-HV
2005 Honda Civic
