Results 1 to 10 of 15
Thread: Why no locked satellites?
    May 2006
    Calgary, Alberta
    I've had it sitting on my balcony rail for half an hour. Do I need to turn something on? I have the com port and baud rate in iGuidance set correctly.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Elsewhere
    Unless you're using a COM port splitter application like XPort or GPSGate, then only one or the other will read the GPS info.
    I believe RR reads the GPS information seperately from iGuidance, so there should be a location to set the GPS's COM port within RR.
    How about the Wiki?
    May 2006
    Calgary, Alberta
    Oh so this doesn't mean it's not working?
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    Elsewhere
    If RR can't see any GPS data coming in, then no.
    How about the Wiki?
    May 2006
    Calgary, Alberta
    I have the com port in RoadRunner set properly. I don't know if there's anything else I need to do though. Or if it matters.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    RR uses mappoint for its data out the box, if you dont have mapoint then RR wont give you any GPS data. It can be set up to take data form free drive and mapmonkey but I dont think it can get the information from iguidance. Set iguidance up for the proper port and change RR to a port you arent using. If Iguidance works properly then everything is working ok. Open your skin in RR skin editor and look for what data stream your skin is looking for.
    If its:
    GPSSAT, GPSSPEED....... your skin is looking for mapoint
    FDSAT, FDSPEED.......your skin is looking for Freedrive
    not sure what mapmonkey is but it might cunningly be MMSAT you get the idea.
    Like I say I dont think it can do this with IG but head over to the RR forum and they will be able to tell you.
    May 2006
    Calgary, Alberta
    Quote Originally Posted by DarquePervert View Post
    Do I need any special hardware to run this? Or do I just set up XPort properly and it'll give me things like speed/direction/locked satellites all from the single GPS receiver and single USB connection?
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Quote Originally Posted by Maheriano View Post
    You don't need any special hardware. Set up xport to split the com port of the gps receiver to 2 different one. Then assign on port to RR and the other to iG.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    Quote Originally Posted by v8 scimitar View Post
    If its:
    actually tha is not true.. RR has native GPS data support.. it odes not need anything else to give you "LONGITUDE, LATITUDE, ALTITUDE, SPEED, GPS SATS LOCKED"). RR gets its map information from external GPS software..(address, ETA, ETR etc..). That is why you should give RR a port number of its own..One for RR and another for your GPS software..(use a port splitter..eg XPORT)
    May 2006
    Calgary, Alberta
    Yup, got it working perfect on virtual ports 5 and 6. Thanks guys!
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  1. Anyone know a way to Print a locked PDF
    By agentloveless in forum Off Topic
    Last Post: 12-09-2005, 04:01 PM
  2. Replies: 4
    Last Post: 09-14-2004, 03:42 PM
  3. Should GPS stay locked thru hibernation?
    By technopsych in forum GPS
    Last Post: 08-04-2004, 01:30 PM
  4. Replies: 14
    Last Post: 07-12-2004, 06:23 AM
