Results 1 to 10 of 11
Thread: iG3 seems a bit... delayed?
    Maximum Bitrate LiquidKernel's Avatar
    Feb 2005
    For some reason iGuidance 3 is showing me on the map 3-5 seconds after I actually get there. iGuidance 2.1.3 would show me 1 second after I got there. The offset is a good 100ft or so.
    I tried using both 3D and 2D to see if maybe it's just slowing down my machine, but no, it works the same way.
    Any one notice this?
    Maximum Bitrate seanz0rz's Avatar
    Jun 2005
    Cal Poly Pomona or Redlands, CA
    ive been having a horrible time with my sound card locking up the computer, and causing everything to go SOOOOOO slow. so that might be your problem (IE another program running, or a hardware issue, etc)
    1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Lifted, Locked, and Armored. CarPc in custom console with molded touchscreen.
    Pictures
    Photobucket is being updated, if a picture i posted no longer works, please PM me.
    Feb 2005
    Well, the thing is that it was perfectly fine with 2.1.3... it's with 3.0 that this started.
    Jul 2006
    South Florida
    Yeah I noticed it as well, most the time it's a very slight delay but it's there and I didnt have it with 2.1.3 either. I know it's not my GPS because it works fine with all other packages and that is with a 11 sat lock.
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    41
    thats odd.. ig3 moves faster and somewhat more smooth than 2.11 did for me
    Live mp3Car Facebook Chat
    Jul 2006
    South Florida
    yeah that is strange, I would say it's the machine but i'm running a 2ghz Pentium M so I think I have enough speed.
    Aug 2005
    Jersey
    Quote Originally Posted by Sonicxtacy02
    yeah actually I was gonna say the same thing... I'm running a PIII/600 MHz & 384 MB ram too (altho I plan to upgrade that very soon)
    Aug 2005
    Pennsylvania
    hmmmmm....IG3 works smooth on my carpc too. Iguidance 2.1.3 was running slow for me one time and my music was skipping (through winamp and wmp) after a huge bump caused my carpc to reset. Tried everything to fix that, but finally decided to do a system restore through windows to an earlier date. If it didn't work, my last resort was starting with a blank hard drive and a fresh copy of windows. But fortunately, everything worked smoothly after the system restore.
    Try checking your system processes while everything is running to see whats slowing you down. O yeah, make sure com port settings are correct for your gps reciever. I think in Iguidance it runs at 4800 bps buad rate. You can do this in your device manager. I forgot to do that once and Iguidance ran slow for me.
    Hope this helps.
    Feb 2005
    Quote Originally Posted by volum3rider
    Hope this helps.
    I will check the useage... might be something acting up.
    Good call on the baud rate, but it is set to 4800 which is the same speed as my receiver. So no mistakes there (set to the same as iG 2.1.3).
    Jan 2005
    cool let us know of any updates
  1. Replies: 0
    Last Post: 04-19-2006, 05:23 AM
  2. what bit is this?
    By W6-Ryan in forum LCD/Display
    Last Post: 03-17-2002, 04:55 PM
  3. sproggy power supply drill bit size?
    By Ces///M3 in forum Power Supplies
    Last Post: 10-08-2001, 09:19 AM
  4. 20 bit = high color or 256 ??
    By hippie in forum LCD/Display
    Last Post: 05-08-2001, 09:12 AM
  5. A simple delayed power-off circuit
    By Oms in forum General Hardware Discussion
    Last Post: 10-27-2000, 06:51 AM
