Results 1 to 6 of 6
Thread: Iguidance v3 install issues.
    Low Bitrate Kato's Avatar
    Oct 2003
    Toronto
    I've installed the latest version of the software, and generated the appropriate maps...when i go to run the program ( umpc or laptop version), i get an error message. "wrong file version data file linkinfo.bin LI105 != LI107 ). Anyone else have this issue. I installed the same software on my work laptop, and everything runs fine. My car pc is a p3 128 megs of ram. Wonder what the issue is? Anyone else have this problem.
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    did you install over a previous version? Uninstall it, delete all the folders, then reinstall.
    Tidder
    Try RevFE
    Oct 2003
    Toronto
    Yes, i believe so...unless their un-installer doesn't properly clean up...
    Jun 2006
    Delete the Inav folder that contains the maps so and then reload the maps.
    Oct 2003
    Toronto
    Done that...even searched for linkinfo.bin before installing..same issue...
    wonder if something in the registry is lingering around
    Oct 2003
    Toronto
    Fixed! Turns out there was "Maps" folder inside the Iguidance folder that gets installed, deleted that and everything is good now.
  1. 2002 Montero Limited Install...
    By Squid in forum Show off your project
    Last Post: 10-06-2009, 04:41 PM
  2. FrodoPlayer + iGuidance V3
    By ergman in forum FrodoPlayer
    Last Post: 04-27-2007, 02:30 PM
  3. Jagputer Install and story log
    By JagPuter in forum Show off your project
    Last Post: 08-02-2006, 09:48 PM
  4. How to make Frodo's RoutisLauncher work with iGuidance
    By dodgetimes2 in forum Software & Software Development
    Last Post: 09-10-2005, 02:47 PM
  5. Having instability issues with your M7NCG 400 and/or XP install?
    By wallaceacura in forum General Hardware Discussion
    Last Post: 07-20-2005, 02:29 AM
