Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 36
Thread: ET301 Eval board
  1. #11
    Maximum Bitrate DJiK's Avatar
    Apr 2005
    Los Angeles (Winnetka), CA
    Quote Originally Posted by Red GTi VR6 View Post
    absolutely positively no idea
    When you find out, let me know.
    If it's more than 1Hz, it might be worth the $100 for me...
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
  2. #12
    _
    Mar 2004
    Little Elm, Texas
    I guess I can just email them and ask....
    Jan Bennett
  3. #13
    _
    Mar 2004
    Little Elm, Texas
    Email back:
    1Hz.
    Jan Bennett
  4. #14
    Registered User
    May 2003
    Quote Originally Posted by kevpriest View Post
    Hi, Red.
    I've read your post on what you were buying, as well as the OEM GPS Install thread, but I'm really not clear on what the advantage is to the OEM GPS over a USB solution. It seems like much more work, so there must be a compelling reason to do it, I just don't know what it is.
    I look forward to your updates on how this card performs.
    Thanks,
    KevPriest
    What red bought is not exactly an "OEM module". Its really is a module on a board with all the necessary parts to make it plug and play. As a whole its no different from a standard USB GPS receiver you can buy off ebay but less the antenna with inflated price.
    You would only use a module if you want to highly integrate it with a tracking device for example, in this case the USB circuitry is not needed. You may wanna work with TTL levels directly fed to the MCU.
    If you want the OEM feel just for the hell of it. Get yourself a decent USB GPS receiver off ebay with external antenna connection, buy an active antenna. Rip the case open and what do you find is a complete PCB with all the bits in, call that your OEM module if you want.
    Here is mine :
    Bluetooth GPS with RFMD chipset and an active antenna.
    Both are bought cheap off e-bay.
  5. #15
    Registered User
    May 2003
    The benefits to running OEM are a more integrated install, instant on, better sensitivity, better lock, etc.
    No need to find somewhere to put that USB GPS unit now.
    What makes it lock faster and all?
    But the USB GPS unit is the same size as this so called evaluation board.
  6. #16
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Red, does this allow the connection between the vehicles speed sensor and the board??
    Michael
  7. #17
    _
    Mar 2004
    Little Elm, Texas
    nope
    Jan Bennett
  8. #18
    Registered User
    Just ordered one, I've been looking for a sirf III oem unit i can integrate into my pc case.
  9. #19
    _
    Mar 2004
    Little Elm, Texas
    aighty - well after all this time I've finally found the time to install the board in the car.
    Now all I need is the battery so it doesn't have to initialize every time I start the car...lol
    Installed the drivers from here: http://www.ftdichip.com/Drivers/VCP.htm
    Told iGuidance to search for it, found it, locked on, and I'm good to go!
    No word on how quick it is or anything along those lines as I'm still sitting here in the garage.
    Will let everyone know when I actually drive the car (sorry, it'll be a while, the weather is too nice here now, been riding the motorcycle to work every day!)
    Jan Bennett
  10. #20
    Maximum Bitrate Dennis5587's Avatar
    Nov 2004
    NY
    any update on how quick it is yet?
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
  1. PC Board Etch on Plexi
    By Sillydipstixs18 in forum General Hardware Discussion
    Last Post: 09-21-2005, 07:12 PM
  2. Hard wire power to the Xenarc board?
    By Will Albers in forum LCD/Display
    Last Post: 09-14-2005, 01:48 PM
  3. Replies: 4
    Last Post: 05-04-2005, 12:24 PM
  4. What controller board to use
    By ricoks in forum LCD/Display
    Last Post: 03-16-2004, 08:37 PM
  5. Some sort of switch board...?
    By claylong in forum General Hardware Discussion
    Last Post: 01-14-2003, 08:17 PM
