Results 21 to 30 of 36
Thread: ET301 Eval board
  1. #21
    _
    Mar 2004
    Little Elm, Texas
    nope - I ride a motorcycle on all but the nastiest of days. Won't have a chance to fully test this for a while. Possibly this weekend, we'll see.
    Jan Bennett
  2. #22
    Maximum Bitrate Dennis5587's Avatar
    Nov 2004
    NY
    ok, thanks...
    I need a new GPS receiver, think this is worth trying? Or should I just get the BU-353
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
  3. #23
    _
    Mar 2004
    Little Elm, Texas
    going this route will be substantially more $$, the board is about $100 then you need an external antenna for it too, so add maybe $75 to that.
    I was willing to pay for a more fully integrated install. This might not be important to you though.
    Jan Bennett
  4. #24
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    Quote Originally Posted by Dennis5587 View Post
    ok, thanks...
    Unless your going to be mounting the receiver inside the case and making it all integrated. I would just stick with the BU-353.
    I've ran the ET301 in my car now for the last 8 months with no problems, but it's signal reception is about the same as the Sirf3 based USB models.
    肚子笑痛了
    S60 Install
  5. #25
    _
    Mar 2004
    Little Elm, Texas
    I'm running the board behind the interior pannel with the rest of my PC.
    My biggest issue with the BU was trying to find a place to put it that wasn't hideously ugly. Sure, you can just slap it on your dash, or slap it on your roof, but IMO, that's half assed.
    Jan Bennett
  6. #26
    Nov 2004
    NY
    yeah, i'll just get the bu, I can put it underneath the carpet on my rear dash, hidden, no metal above it, should work fine... just have to worry bout keeping it from vibrating...
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
  7. #27
    FLAC SnyperBob's Avatar
    Nov 2001
    Illinois
    Looks good, but if I were to go with a more OEM solution, I'd go with something that features dead reckoning. Looks like the only advantage over other USB units is this unit has the on board battery. That helps in not having to lock on, since it's essentially always-on. (Hot start 8 seconds)
    Similar to the Holux GPSSlim 236. The Holux is bluetooth wireless, and has the ability to use an external antenna. The two (Yours and the Holux) have the same specs.
    The Holux is what we use for Playstation Portable GPS, since it doens't require power from the USB cable
    Looks good Red. For about the same price I think I'd rather have blue tooth capability as well. (You can also run it straight off USB, serial, and have an external antenna).
    http://www.semsons.com/hogpwigpsres.html
    www.mobile-effects.com
    Free file hosting, picture gallery hosting for installs, PM me.
    Internet's first Front End Skin browser, featured installs, downloads, links, informative articles - all free to registered users.
  8. #28
    Nov 2001
    Illinois
    any update on how quick it is yet?
    Hot/Warm/Cold Start: 8/38/42 sec.
  9. #29
    May 2003
    Miami, FL
    Well I have the Ublox dead reckoning setup as well. The problem i'm having is not being able to get access to my speed pulse. Well more like I just dont want to take half the car apart in order to get to it. So of course that project sits waiting in a box for me to install, I bought the et301 just as a temporary solution and it stuck.
    肚子笑痛了
    S60 Install
  10. #30
    Maximum Bitrate S4Per's Avatar
    Jan 2004
    Seattle, WA
    Red - any details you can share at this point re: results after implementation? comparison to bu-353?
    thanks,
    Per
  1. PC Board Etch on Plexi
    By Sillydipstixs18 in forum General Hardware Discussion
    Last Post: 09-21-2005, 07:12 PM
  2. Hard wire power to the Xenarc board?
    By Will Albers in forum LCD/Display
    Last Post: 09-14-2005, 01:48 PM
  3. Replies: 4
    Last Post: 05-04-2005, 12:24 PM
  4. What controller board to use
    By ricoks in forum LCD/Display
    Last Post: 03-16-2004, 08:37 PM
  5. Some sort of switch board...?
    By claylong in forum General Hardware Discussion
    Last Post: 01-14-2003, 08:17 PM
