Results 1 to 10 of 10
Thread: GPS outages
    Aug 2005
    south GA
    GPS outages
    ok... i guess im reading this correct. GPS is out for the moment. only thing i could receive was time and date last night. so i checked a few websites.
    http://www.navcen.uscg.gov/ado/DgpsCurrentStatus.asp
    and
    http://www.navcen.uscg.gov/Ftp/gps/status.txt
    69 Mustang
    408 clevor AFD 2v heads - Viper T56
    Audio:RUX-C701, PXA-H701, MRV-F545, (2) MRD-M1005, SIR-SC-H1, DMHD1000, Dayton Audio: (2) RS180-4, (2) RS28F-4, (2) RSS265HO-44 DVC
    _
    Mar 2004
    Little Elm, Texas
    can anyone confirm this?
    Jan Bennett
    Aug 2005
    south GA
    confirm problems
    Quote Originally Posted by Red GTi VR6 View Post
    please do.. somebody able to test out there... i can see all satelites. but only thing i receive is time and date. on a known good setup. laptop with a BU353. i setup mappoint on another laptop and tested gps install with oem software and it allows me to communicate via WAAS coldboot, warm boot etc etc. but still only info i receive when in mappoint is time and date.
    ill check again this afternoon.
    69 Mustang
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    Mines working fine and dandy
    May 2005
    Vienna, VA
    mine was working just minutes ago.
    iGMon - Integration between iGuidance and Road Runner
    CFX - Skin for Road Runner
    Aug 2005
    south GA
    gps status
    Quote Originally Posted by b8bboi View Post
    great!! mine should be working when i get home... or i have more troubleshooting to do... thanks for testing.....
    69 Mustang
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    That first link is status for the DGPS transmitters, which is part of a 'Differential' GPS system. Land-based transmitters that send out a correctional signal to correct for the enforced drift in satellite-based transmissions. That shouldn't affect anything unless you have a seperate DGPS reciever.
    I haven't had any problems with my GPS last night or this morning just outside of Conyers.
    Aug 2005
    south GA
    goofy
    now i feel stupid..... its prolly the same problem as this:
    USB GPS Globalsat bu-353 will connect one day, but wont the next unless i reinstall !
    ill see when i get home if not ill do as suggested in the above post and move on.
    thanks all.. sorry for the bother..
    69 Mustang
    FLAC Marvin Hlavac's Avatar
    May 2005
    For the past three and a half years I've been using GPS navigation at work, 12 hours a day, 5 to 6 days a week, but I have never experienced any to me noticeable problem with GPS network. Even if something happens to one satellite, there are still several others that are working fine.
    I’d say that if a user thinks something is not right with the GPS network, it is very likely just an issue with his/her own setup.
    Apr 2005
    the first link is for DGPS ground stations, only DGPS receivers near the down stations would get affected for DGPS function, GPS itself should still work.
    the second link I don't know. but a receiver doesn't need all satellites to get a lock in. there are more than 30 GPS satellites in the sky, only 24 is needed for the network, and a receiver only needs signals from 3-4 of them to work. it's not possible that your problem was from a total GPS shutdown.
  1. PPC Car GPS and MP3 mini How To
    By hotrod_nut in forum General Hardware Discussion
    Last Post: 02-25-2008, 01:24 PM
  2. Cell Phone GPS
    By EBFoxbat in forum GPS
    Last Post: 09-14-2005, 06:45 AM
  3. Replies: 8
    Last Post: 03-26-2005, 10:29 AM
  4. few gps questions
    By fuctup in forum GPS
    Last Post: 03-02-2005, 01:40 AM
  5. Replies: 9
    Last Post: 10-25-2004, 01:34 AM
