Results 11 to 20 of 27
Thread: IG3.0 Coordinates Are Back
  1. #11
    Jan 2005
    Phoenix, AZ
    You RULE. I was so annoyed the other day when I needed this to get to a hiking spot.
    So happy to have it back!
    1998 BMW M3
    Mods: Staggered SSR Competition wheels : M Roadster Short Shifter : JTD Aluminum Underpanel : Koni Adjustable SAs : Eibach Pro-kit springs : European clear corners and side markers : Hardwired V1 automatic door and radar detector
  2. #12
    Oct 2006
    Raleigh
    This mod is working for me kudoz, it wasn't that easy for me cause I am new at this site I was looking for the import function in the reshack menu couldn't find one. For all the newbies to import click on "action" then select "add new resource"
  3. #13
    FLAC john1701's Avatar
    Mar 2004
    Fort Myers, Fl
    ok, just upgraded to ver 3.01. Dialog 1092 sortof works. It is not showiing the number buttons .
    1004 works but not 1092. For version 3.01, just fyi
    CAR:2001 Ford Crown Victoria
    PC: Acer EEE 900HA with Win7 with CF 2.0.
    Memory:1G
    Drives:160gig
    WI-FI:Cingular
    GPS:IG2k9
    Screen:Xenarc 700TSV
    The Florida Meets Thread
  4. #14
    Raw Wave lostreception's Avatar
    NY
    i havent had time to upgrade but im beginning to hate inav
    they removed that because of this mod possibly? ( i should be so flattered but... why do they do things counter productive
    i bet igQWERTY is borken for sure now too
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
  5. #15
    Mar 2004
    Fort Myers, Fl
    well as long as you keep 3.0 and not 3.1, the mods work.
    Memory:1G
    Drives:160gig
    WI-FI:Cingular
    GPS:IG2k9
  6. #16
    Constant Bitrate AngryMan's Avatar
    Aug 2005
    Lewiston, Maine
    coiudl someone just make this into a patch exe to save some of us some work?
    I assure you, I am NOT lazy, but I am spread so darned thin most of the time I hardly have time to eat, let alone run time consuming res hacks on applications like this. either way, I am glad someone found out how to add this feature to iguidance. I defenitely have had a need for coordinate entry more than a handful of times.
    keep up the good work
    p.s. thanks for the warning to stay away from 3.1
    .______
    / '__|__\____ VW CarPC project
    \(o)_____(o)/ Full Spead Ahead!
    Props to my Sponsor, Summit Adventure Systems Mobile Climbing Walls
    www.summitadventuresystems.com
  7. #17
    Maximum Bitrate LiquidKernel's Avatar
    Feb 2005
    Amazing! Thank you for the credit, but I think I was just the first person to bring up the topic.. I didn't send the res file. So technically, someone else deserves the credit!
    I am super glad this worked... time to mod!
  8. #18
    Aug 2005
    Lewiston, Maine
    I would like to point out that it might be confusing for a noob to add this mod.
    firstofall, if you are using the fullsized "laptop" version of iguidance, make sure you use the code in the second post.
    secondly, you will need to import the 1092.res file from the zip, by opening reshacker, then in reshacker click file, open, and point to the iguidance.exe.
    then click on dialog and click action on the tool bar, down at the bottom of this menu you will see "add new resource".
    point to the 1.92.res file you downloaded from the zip.
    once it is in there, you will need tochange the content to thestuff for the full sized iguidance. just navigate to the 192. dialog, open it up and close the box that pops up (if it is so big you cant see the X to close the box, just hit escape and it will go away) then select all the code in that box and delete it, then paste the code in from the second post on here.
    im falling asleep as I type this, so I might not be making any sense...
    .______
  9. #19
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    I have sometime to play with 3.01 yesterday. This is what john1701 talking about regarding to dialog 1092
    It's just suck.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  10. #20
    NY
    Quote Originally Posted by MatrixPC View Post
    It's just suck.
    the mod can be done but must be done manually with 3.01 or someone needs to make a patcher of the 3.01 version the patcher is exe specific thats why i suspect this is the problem but i cant confirm as i don't have 3.01 and only 3.0 BTW is there any real benefit to 3.01?
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
  1. Touchscreen starts off X-Y coordinates for first 10 minutes.
    By judoGTI in forum General Hardware Discussion
    Last Post: 04-02-2005, 10:24 PM
  2. Replies: 4
    Last Post: 03-23-2005, 11:33 AM
  3. How to get to back of headunit
    By nick8197 in forum Newbie
    Last Post: 02-11-2005, 12:55 PM
  4. Replies: 5
    Last Post: 01-03-2005, 09:39 PM
  5. Where can i find a lcd 20x4 with led back light
    By Dan in forum General Hardware Discussion
    Last Post: 04-28-2000, 01:14 PM
