Results 1 to 6 of 6
Thread: Question about USB powering of the GPS receiver.
    Mar 2004
    Maryland/NOVA
    Will my GPS receiver work better if I connect it directly to the mobo's USB port rather than on a 4 port non-powered hub?
    I'm assuming as long as it's locking onto satellites its working to its' full capacity.
    But i've always wondered if connecting it directly to the mobo would squeeze a little more performance out of it.
    Thanks!
    2001 Acura CL traded for a 2006 Subaru Legacy GT
    7" Lilliput Touchscreen
    NANO-ITX+m1-atx
    512 DDRsodimm
    60g SATA Laptop HD
    4x Apple DVDslot
    digimoto OBDii
    mS GPS
    mini BT keyboard
    relocated HU faceplate
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Probably not.
    It is always a good idea though to have the devices you really depend on plugged straight into the PC.
    Tidder
    Try RevFE
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    If its working its working I would think. Only time I could see it make any odds is if your drawing too much power from the hub but you would soon know if you were.
    Visit my site V8 Scimitar
    SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit. 4 years installed and it just keeps running!
    Constant Bitrate Goddy's Avatar
    Dec 2004
    Netherlands
    My experience is that it really helps to hook it up straight to the mobo. I once used an extension USB cable and that turned out to have less power and much worse signal. Since I removed the extension cable I have a lot better and sooner lock.
    So if you are using a non-powered hub its like the same as using an extension cable.
    2 options: power your hub or connect it straight to the mobo
    Elsewhere
    I do believe he's talking about connecting to the USB headers on the motherboard, not a USB port on the motherboard vs a USB hub/extension.
    But I agree that it shouldn't make a difference. If it's working, it's working.
    How about the Wiki?
    Dec 2004
    Netherlands
    As far as I can see he said connect it directly to the mobo instead of a 4 port non-powered hub ?!
  1. EBAY: Xenarc 700Y, GPS Receiver, USB Touchscreen Controller
    By King_Aero in forum Classified Archive
    Last Post: 10-11-2005, 04:17 AM
  2. WTB: USB GPS receiver
    By mykolJay in forum Classified Archive
    Last Post: 06-22-2004, 11:00 AM
  3. WTB: GPS receiver (USB)
    By Mastero in forum Classified Archive
    Last Post: 06-18-2004, 12:25 PM
  4. HOLUX GM-210 USB GPS Receiver
    By Deadnick in forum GPS
    Last Post: 05-19-2004, 07:02 AM
