polo6979 - GPS versus Tint is just science. Most tints use metallic elements. These elements distrupt/distort the RF. You can get tint that is not metallic, but its generally more expensive and not as effective.
OK.. based on recommendations I'll give the BU353 a try.... Question though...
My windows/tint are totally RF blockers, even the windshield has oem metallics in it.
So it has to go outside..... I'm pretty picky about appearance, so no magmount, wire thru the window for me. It has to be either 100% concealed or OEM mounted.
Currently, the Earthmate is in the plastic "wiper cowl" (the trough that hold the wipers and mechanism). On the Celica the cowl is above the firewall, relatively flush with the hood, so it can get warm. I've touched the Earthmate after a hot, long drive... and it isn't any warmer than the body of the car.
So.... Given that the Earthmate got as many as 8-9 SATS in the current location on a good day.... Think I should just place BU-353 in the present location?
LinkBack URL
About LinkBacks
