Page 12 of 15 FirstFirst ... 23456789101112131415 LastLast
Results 111 to 120 of 142
Thread: Tired of "ABC" keyboard in IGuidance? iGQwerty
  1. #111
    Raw Wave lostreception's Avatar
    NY
    Quote Originally Posted by Naesstrom View Post
    anyone managed to get this to work with the 2.1.2 release... we poor bastards in europe will never get a v3... and while waiting for Mapfactor v7 IG is the best navi we have!
    if you use reshacker as described in my post linked in the 1st post of this tread about what to add to the dialogs it should???? work its been a while since i ran 2.x so it may not . it also depends on how much they changed the inner workings of iG, sorry without a way of testing i have no idea :-/
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
  2. #112
    Jul 2006
    iGuidance 3.0.1
    Can you release the process you used to update the coords for the keyboard patcher? I'm using iGuidance 3.0.1 and your patcher only supports 3.0. I'd be happy to release a patcher for you if I only knew what you did.
    Edit: I think I found it in an earlier post...I'm going to try it now. Thanks!
  3. #113
    Jul 2006
    OK, patching the Dialog 1008 caption to "OSK" worked for iG 3.0.1 and igqwerty 1.0c. I have it running on two machines, my actual carpc works fine, my testing pc works but the old keyboard shows behind it. I figured out that it was because I had my DPI changed to 120dpi instead of 96dpi (default). I've already reshacked the "Menu", "Mute/Unmute", "+" and "-" buttons from the display. The "Menu" button actually still works, you just can't see it. The only thing I can't seem to find in reshacker is that when IG is muted, the little "x" shows up that would normally show over the top of the button. Once I find out where to get rid of that, my IG 3.0.1 mod will be perfect for me.
  4. #114
    Low Bitrate esko's Avatar
    Jun 2007
    Quote Originally Posted by ChrisBensch View Post
    Can you upload the files please. Thanks!
  5. #115
    Oct 2005
    does anyone know if this work for v4.0?
  6. #116
    Sep 2005
    This patch won't work for 4.0, it's specifically for 3.x.x. If I had 4.0 I could make a patch like I did for 3.0.
  7. #117
    Constant Bitrate stealinfool's Avatar
    Dec 2005
    Orlando
    I've got 4.0 (but my .exe files have a version of 3.0). It would be sweet to have a patch for this. It takes twice as long with the ABC!
  8. #118
    May 2006
    Quote Originally Posted by stealinfool View Post
    I got Ig 4.0 to work with IgQWERTY 1.0c....
    Go Here to read on how to reshack iG coordinates back into ig3:
    IG3.0 Coordinates Are Back
    Still in reshack
    open dialog 1004. Between the caption quotes type DESTINATION. compile script.
    open dialog 1044. Between the caption quotes type MENU. Compile script.
    Open Dialog 1008. Between the caption quotes type OSK. Compile script.
    Save and close Reshack
    Enjoy!
    Rich
  9. #119
    Jun 2007
    Quote Originally Posted by RichP714 View Post
    Still in reshack
    Enjoy!
    Rich
    That's great but can you provide details for the rest of us? Did you have to use and of the Installers for igCoordPatcher.exe or iGQWERTY_v1.0c.exe or reshack these?
    or do you have to reshack the iGuidanceUMP.exe (VERSION 4.0) file?
    May 2006
    Quote Originally Posted by esko View Post
    Well, those kind of ARE the details, that's all I did to get it to work
  1. Replies: 570
    Last Post: 11-05-2009, 03:49 PM
  2. Replies: 17
    Last Post: 06-15-2006, 01:46 AM
  3. iGuidance Full Screen w/o Keyboard
    By bruha in forum GPS
    Last Post: 04-04-2006, 01:23 PM
  4. iGuidance Font Size Fix summary thread
    By Viscouse in forum GPS
    Last Post: 03-28-2006, 07:21 PM
  5. iguidance keyboard shortcuts?
    By liquid_smoke in forum GPS
    Last Post: 12-03-2004, 10:56 AM
