Page 6 of 15 FirstFirst 123456789101112131415 LastLast
Results 51 to 60 of 142
Thread: Tired of "ABC" keyboard in IGuidance? iGQwerty
  1. #51
    Raw Wave lostreception's Avatar
    NY
    Version 1.0a is availible for download [see 1st post]
    anyone who has a problem please do the following:
    1. close iGQwerty
    2. Create a new txt document in the root dir of iGQwerty
    3. Rename that file igq.debug (this will obviosly have no file association)
    4. Rerun iGQwerty
    5. After the problem as occured check the root Directory of iGQwerty again
    6. Locate debug-igq.txt
    7. Attach it here with a description of what is happening including your version of Windows XP, Screen Resolution, Front end (if any), etc
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
  2. #52
    Oct 2005
    Raleigh, NC
    Not working with iGLaunch
    This is fantastic! The only issue I am having is, I use iGLaunch to properly embed Iguidance into Roadrunner. I suspect that the exe name change is not allowing IG-Q to work in this mode. Are there any settings that can be changed to make this compatible? I need to use iGLaunch and would really like to have a qwerty keyboard.
    Thanks for your effort and a great add on.
    RRG
    iGLaunch link below
    [Release] iGLaunch v3
  3. #53
    NY
    Quote Originally Posted by rrgcsfb View Post
    RRG
    iGLaunch link below
    Just tried it with ig launch it didnt load the 1st time but after clicking on it it loaded ok
    if iglaunch is loaded standalone it works fine
    so roadrunner is stealing focus apparently but gives it back after the intial load (at least here it does)
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
  4. #54
    TMF
    TMF is offline
    Constant Bitrate TMF's Avatar
    Apr 2006
    Waterloo, IA -- cvmusclecars.com
    Quote Originally Posted by lostreception View Post
    I looked into this and maybe its just my machine or a change i made with the newest release but i do not have this problem please try again and let me know
    I just downloaded 1.0a and confirmed I have the same problem. Without IG-Q, it works fine but with it it cannot find addesses correctly.
    Here are my steps:
    Downloaded and patched UMPC for the coordinates. Then I put a shortcut to IGQ in the Startup Folder for All Users. I also put one on the desktop to make it easy to test.
    Start UMPC from the desktop, nothing else running.
    Press Menu, Destination, Address, Change State
    IGQ OSK is showing on the screen now.
    Press I O (for IOWA) and it is in the shown in the Blue Bar so press OK.
    UMPC then says I've selected ALABAMA (AL) ?!
    Umm... no.. Try again.
    Change State
    I O W A Ok
    Still Alabama!
    Something is not working.
    Let me know if you want me to try something else. (I'm also a Windows programmer) You're so close it has to be something simple!
    John
  5. #55
    Nov 2004
    Weird. I've played with it again, and it looks random: sometimes it behaves correctly, sometimes not. I can't figure out a common pattern.
    Let me test this again, and I'll come back to you when I find a common pattern ... if there is!!
    André
  6. #56
    NY
    hey guys ill take a nother look then it works flawlessly on 2k (my dev machine)
    but ill have to test it on xp a bit more
    is anyone having the runtime error 28 anymore with the new version?
    thanatos any luck on frodoplayer?
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
  7. #57
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by blk02si View Post
    Well i rebooted the PC and now it works for me if IG is running stand alone. If its embedded into the latest version of RR i throw the 'error 28' box. Wish there was a way to hardcode this into the ig.exe instead of having another application take it over when you launch the OSK.
    Oh yeah the arrow and space bar also work for me
    Hehehe I TRIED that once, still have the Modified iG here. Problem is that there are not enough buttons on the rows to simply change out the letters ect. The KB needs re-arranged as lostreceptions app does.
    Here is a screen cap of the iG keyboard I was TRYING desperately to get working at one time. There are no other helper applications running when this screen cap was taken:
    (This was taken in the middle of skinning iG to match my skin)
    All I could do was take the left over letters at the end of the rows, and move them to the bottom row The good thing was that the keys, when pressed, coorispond to what they are labled and all, but thats about as far as I could get. (Oh, this was donw with a hex editor)
    My Fiero Build Thread
  8. #58
    NY
    interesting, john you mind making a patch for that version i have an idea
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
  9. #59
    May 2006
    I'm no longer getting error 28, now it's 55 (file already open) and then IGQwerty crashes and closes.
    Running on XP SP2 with an Aopen Dual Core CPU and 1G RAM.
    StandAlone I get the Qwerty keyboard, but entries don't 'take' as in Andrel's problem
    In RR (newest beta, but not imbedded) I get the error 55 and IG3's regular keyboard
    Attached Files Attached Files
  10. #60
    NY
    Version 1.0b
    - Fixed loop in Trying to show OSK
    - Attempted to Fixed Runtime error 50 which was the debug file hanging in the open state and not closing properly
    - Other small issues fixed
    Im still unable to duplicate the keyboard problem some of you have been experiencing I'm sure its something simple and ill have it sorted by the next release
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
  1. Replies: 570
    Last Post: 11-05-2009, 03:49 PM
  2. Replies: 17
    Last Post: 06-15-2006, 01:46 AM
  3. iGuidance Full Screen w/o Keyboard
    By bruha in forum GPS
    Last Post: 04-04-2006, 01:23 PM
  4. iGuidance Font Size Fix summary thread
    By Viscouse in forum GPS
    Last Post: 03-28-2006, 07:21 PM
  5. iguidance keyboard shortcuts?
    By liquid_smoke in forum GPS
    Last Post: 12-03-2004, 10:56 AM
