Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: NMEA Decoding?
  1. #11
    Mar 2007
    The View of the Hyperterminal DATA is attached
    Name:  GPS Test Data.jpg
  2. #12
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC - Alexandria, VA N/W Area - NOVA
    Quote Originally Posted by secmem View Post
    Thanks for the reply....
    I did the same as you mentioned, but i couldnot see the NMEA messages but could see only some junk data of symbols..
    I even tried with the TSIPMonitor32.exe, but could not get the data in it. Please help me with steps, how to use TSIPMonitor.exe.I even gone through the Lassen LP Manual.
    The manual is explained according to the starter kit. but I m not using Starter kit instead I interfaced Lassen LP module to PC serially through Max232.
    waiting for the reply..
    try adjusting your speed (baud). some receivers send out at 9600
  3. #13
    Mar 2007
    3.3V Back up Battery is required for the GPS to give NMEA data?
    Quote Originally Posted by W3bMa5t3r View Post
    I have tried for different baud rates, but the junk data remains same. At present i did not connected any backup Battery to the Lassen LP GPS module.Please confirm, whether the 3.3V Back up Battery is required for the GPS to give NMEA data.
  4. #14
    Mar 2007
    Create a new connection, specify the port, speed,settings = 4800, 8, N, 1 (or something like that.. )
    Save it, Hit connect. You should start seeing the GPS/NEMA sentences flying by...
    Anyone help me in getting NMEA massages in Hyperterminal. I want to know whether Back up Battery is needed for getting NMEA data
  5. #15
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    have you confirmed your device works at all ? looks like its knackered to me
  6. #16
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    They don't usually need the battery, after reading their website I'm guessing its outputting TSIP binary protocol...
    - The Lassen LP GPS receiver has a single I/O port. The device is delivered from the factory with the TSIP protocol configured on this single I/O port. -
    It needs changing to NMEA.
    Edit - which you did ask!
    Pls let me know , how to enable the NMEA data out in Lassen LP GPS module using Hyperterminal
  7. #17
    Oct 2003
    Madrid
    You tried TSIPMonitor32? It says you can change it with that.
    What do you get in the TSIPMonitor window?
  8. #18
    Maximum Bitrate carabuser's Avatar
    Aug 2003
    CA
    Interested in testing this unit. We might end up using it for one of our school projects. Would appreciate any updates with it. Thanks.
    Current Status: For Sale
    Specs
    - 1.5Ghz Toshiba Laptop (available - no screen)
    - Indash Motorized 7" VGA TS
    - DeLorme GPS (sold)
    - Power Inverter (sold)
    - Pioneer HU (sold)
  1. Need help decoding a one wire databus...
    By Dexter in forum Hardware Development
    Last Post: 03-04-2006, 09:09 PM
  2. sirf or nmea in MP?
    By johnwrx in forum GPS
    Last Post: 11-09-2005, 06:44 PM
  3. Dvd Decoding
    By dolbyrsx1 in forum Newbie
    Last Post: 03-21-2005, 01:29 PM
  4. How to switch to sirf from nmea & push to fix mode
    By qbee in forum Software & Software Development
    Last Post: 03-07-2005, 07:59 PM
  5. Replies: 2
    Last Post: 11-11-2004, 05:51 AM
