Results 1 to 10 of 18
Thread: NMEA Decoding?
    Sep 2006
    Exclamation NMEA Decoding?
    I want to ask if some one have decode the NMEA standard signal generated by the GPS receiver, using microcontroller(preferable) or the serial port with his own software?
    If someone do this thing, please send me the details and the steps to do this brililiant thing.
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Sep 2006
    Question
    Yea, i have read about the NMEA, but still there are some questions.
    One of them, 4800 baud per second, how much the baud is? and is the "no parity" bit sent or not?
    Constant Bitrate Jeep's Avatar
    May 2004
    Sweden
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Hamzeh View Post
    Try it with hyperterminal first and see.
    Dec 2006
    Belgium, Lokeren
    If still needed :I did some test with a PIC 18F455 and an LCD display.
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    Take a look at the Perl Library, GPS::NMEA
    Mar 2007
    LAssen Lp GPS NMEA data
    Quote Originally Posted by 0l33l View Post
    Pls let me know , how to enable the NMEA data out in Lassen LP GPS module using Hyperterminal
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC - Alexandria, VA N/W Area - NOVA
    Quote Originally Posted by secmem View Post
    Create a new connection, specify the port, speed,settings = 4800, 8, N, 1 (or something like that.. )
    Save it, Hit connect. You should start seeing the GPS/NEMA sentences flying by...
    Mar 2007
    i couldnot see the NMEA messages but could see only some junk data of symbols..
    Quote Originally Posted by W3bMa5t3r View Post
    Thanks for the reply....
    I did the same as you mentioned, but i couldnot see the NMEA messages but could see only some junk data of symbols..
    I even tried with the TSIPMonitor32.exe, but could not get the data in it. Please help me with steps, how to use TSIPMonitor.exe.I even gone through the Lassen LP Manual.
    The manual is explained according to the starter kit. but I m not using Starter kit instead I interfaced Lassen LP module to PC serially through Max232.
    waiting for the reply..
  1. Need help decoding a one wire databus...
    By Dexter in forum Hardware Development
    Last Post: 03-04-2006, 09:09 PM
  2. sirf or nmea in MP?
    By johnwrx in forum GPS
    Last Post: 11-09-2005, 06:44 PM
  3. Dvd Decoding
    By dolbyrsx1 in forum Newbie
    Last Post: 03-21-2005, 01:29 PM
  4. How to switch to sirf from nmea & push to fix mode
    By qbee in forum Software & Software Development
    Last Post: 03-07-2005, 07:59 PM
  5. Replies: 2
    Last Post: 11-11-2004, 05:51 AM
