If you are building a CarPC then you are probably interested in using a Windows-based GPS solution. In this case the 10-pin connector has no bearing over what you can or can't use.
If not, then you shouldand find out what they call the port/protocol. Then, you can look for GPSes that support that feature.
LinkBack URL
About LinkBacks
