Results 1 to 3 of 3
Thread: Speedcams & MapMonkey/Freedrive in Advanced mode
    Jun 2005
    Hi!
    I just managed to get decent maps for Finland & coordinates for all the speedcams. I also have Freedrive and MapMonkey working.
    I have rather old iGps (GPS Mouse?) unit.
    I just noticed that when i turn the Advanced mode ON in the MapMonkey,
    FD or MM cannot connect to the COM port. When i turn it OFF, everything works ok. So far thats fine..
    But the question is:
    I assume that this means, that the iGPS module is not SIRF compliant?
    And if so, will i really miss the SpeedCam notifications in FD? It still shows
    cams as little icons beside the road, but will i get any pre-notifications when approaching a cam?
    or is it that my speedcam CVS file is in wrong format, does the speedcams have to have the "GATSO" string as first "type" parameter to actually get the notifications for it?
    Heres part of the CVS that i imported into FD:
    23.677, 61.511933, Nopeuskamera -Lielahti @70
    24.781944, 60.554722, Nopeuskamera -Noppo
    24.749444, 60.548333, Nopeuskamera -Rajamäki
    24.686667, 60.534167, Nopeuskamera -Rajamäki
    is this ok? or does it have to be like this:
    "GATSO","23.677", "61.511933", "Nopeuskamera -Lielahti","70"
    "GATSO","24.781944", "60.554722", "Nopeuskamera -Noppo"
    "GATSO","24.749444", "60.548333", "Nopeuskamera -Rajamäki"
    "GATSO","24.686667", "60.534167", "Nopeuskamera -Rajamäki"
    Which one is the RIGHT format for speedcams in FD, so it will give warning
    when approaching one?
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    FD doesn't need SIRF to do the cameras.
    Quote Originally Posted by From the FreeDrive readme.txt
    The default csv file should be in the format Lontitude,Latitude,Name the Name also needs to be in the
    format of name@speed so for example -2.10855,53.0786,GATSO:0222@30 "GATSO:0222" being the name of the
    camera and 30 being the speed. This is the standard format which PocketGPS uses on there site.
    Jun 2005
    Ok! Thanks for this! I'm currently installing my pc into car, so i will soon be able to actually test it!
    CVS format seems to be right..
  1. Quest for 800x480
    By ptk in forum LCD/Display
    Last Post: 01-04-2010, 11:42 AM
  2. Creative Audigy2 PCMCIA and advanced mode on M2 12000?
    By Rilot in forum General Hardware Discussion
    Last Post: 06-30-2006, 08:26 AM
  3. XM Satellite Radio to Unveil XM Advanced Services at 2006 Consumer
    By Will Albers in forum General MP3Car Discussion
    Last Post: 03-27-2006, 09:49 PM
  4. Where's Advanced GPS Mode?
    By fatejd in forum Map Monkey
    Last Post: 01-25-2006, 06:08 PM
  5. BASIC Stamp question
    By Banderon in forum General Hardware Discussion
    Last Post: 05-07-2004, 09:33 AM
