Results 1 to 7 of 7
Thread: bu-353 not getting signal as good as it used to...
    Jun 2006
    Angry bu-353 not getting signal as good as it used to...
    ... so i havent changed anything, but i noticed that my gps just isnt working as well as it used to! on my iGuidance the signal is red (unusable) allllll the timeee, and it takes MANY, MANY minutes to get some signal... sometimes it just doesnt...
    ive unplugged the unit and plugged it back in, still no signal... restarted computer (usually hibernates) and still NOTHING!
    the placement is fine as it used to work perfectly before (always green, all the time)...
    i just dont know what to do! this is making me very frustrated...
    any suggestions?
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    See if iG is using the wrong com port. I used to have trouble with it forgetting which port was active and when I would check it had defaulted to com1. There are several threads about various fixes if this is your issue. Good luck.
    ~Jimmy
    Jun 2006
    its the right port... when it isnt the right port, the arrow will be gray, not red.
    Nov 2005
    Austin, Texas
    OK. Just some suggestions to narrow it down:
    Try reinstalling drivers. Test with the program that comes with the driver. If still not recieving good, then it isn't iG. Uninstall completely and stretch cable out temporarily to outside of car. Test on another PC. Good luck.
    ~Jimmy
    Jun 2006
    i tested the reciever with another computer (same mounting place) and it works great....
    GAH! and it isnt running through a hub, its directly attatched to my M10000
    Constant Bitrate randomjohn's Avatar
    Sep 2005
    CT
    ditto. I recently moved my wifi antenna away from it, and that helped a little, but it's still nothing like it was when I first got it. No other settings have changed for me, either. Very odd
    GA-K8VM800M, Sempron 64 2800+, 512mb DDR400, D-Link USB BT, Linksys .11g NIC, 250gb IDE, BU-353, SIR-ALP1 w/ MJS, DSATX 220w, DWW-700H
    Worklog: http://www.mp3car.com/vbulletin/worklogs/65059-03-jetta-if-i-can-any-idiot-can.html
    Now with pictures!
    Low Bitrate I302K's Avatar
    Mar 2006
    NY
    Mine Does The Same Thing And It No Were Near My Wifi It Keeps Droping The Signal
    Xenarc 700TSV - 80GB HD -Xenarc 700TSV - 512MB -BU353 GPS - iGuidance 3.0 - RoadRunner - Opus ITX Mini Vehicle PC Case - Opus 120W - XM RADIO - WIFI - CDR\DVD
  1. Cell Booster / Amplifier
    By GruvThang in forum General Hardware Discussion
    Last Post: 07-28-2004, 06:35 AM
  2. FS: LCD Controllers - $90.00+shipping
    By infrared in forum Classified Archive
    Last Post: 07-20-2003, 08:30 AM
  3. Another power good question (Sorry)
    By ZeroLogic in forum General Hardware Discussion
    Last Post: 08-20-2000, 12:02 AM
  4. power good signal - help me please!
    By BluCivic93 in forum General Hardware Discussion
    Last Post: 08-10-2000, 10:16 PM
  5. FM Modulator?
    By mp3vw in forum General Hardware Discussion
    Last Post: 11-11-1999, 12:08 PM
