Results 1 to 5 of 5
Thread: Strange GPS problem when booting directly to front end
    Sep 2006
    Richmond, Tx: USA
    With the help of this guide I was able to boot directly into Road Runner. Everything seemed to be working fine till I opened GPS and found out that for some reason GPS is not locking to any settelites. So I imported the orignal registry (with Explorer as shell) file and restarted the computer and everything started working again.
    What could be the connection between GPS unit and explorer ? that it does not work when window boots directly to frontend ?
    Any idea ?
    Elsewhere
    If the GPS is USB, it may be that the serial-USB drivers aren't loading without Explorer as the shell.
    Just an idea.
    How about the Wiki?
    Sep 2006
    Richmond, Tx: USA
    Quote Originally Posted by DarquePervert View Post
    Just an idea.
    Hmmm, maybe but I highly doubt that Explorer have any connection with drivers.
    How are you using your front end ? Did you set it up as shell ?
    Elsewhere
    No, I don't have it setup as a shell. SD merely loads as an app.
    How about the Wiki?
    Sep 2006
    Richmond, Tx: USA
    found out the problem.
    When booting with RR as shell, Xport does not load and because of that IGuidance does not work in RR. So to overcome this, I use Explorer (from Blue Devil Skin) and manually run Xport and that take cares of the problem.
    Is there any other way to load Xport, when using RR as shell ? I've tried putting it in "Startup" but it does not work that way.
  1. FAQ: Boot directly into your front end
    By d_sellers1 in forum The FAQ Emporium
    Last Post: 03-06-2010, 05:22 AM
  2. Replies: 6
    Last Post: 07-04-2006, 01:20 AM
  3. Starting Front End From Scratch
    By spuzzdawg in forum Linux
    Last Post: 03-21-2006, 12:30 PM
  4. BASIC Stamp question
    By Banderon in forum General Hardware Discussion
    Last Post: 05-07-2004, 09:33 AM
