Results 1 to 7 of 7
Thread: 1st post here...GPS to work with this monitor
    Nov 2006
    this is going into my boxster.
    what is the easiest way to hook up a GPS to work with this? any links or info it appreaciated
    its a Liliput touchscreen.
    what will i need in order to make this work?
    any help is appreciated, id also like to instal a rear view camera to work with it too so help on that is welcome as well
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by djomlas View Post
    Sure, all you need is a computer. There is no standalone GPS unit that I know of, that has a video/VGA output.
    Michael
    Nov 2006
    can i use laptop? any links on laptop use and what i need wire wise to get this to run?
    ive never done such thing, i usuall only deal with HP
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Well, since a laptop is a computer, you should be able to get it to work.
    You need to READ READ READ. I suggest you start here
    http://www.mp3car.com/vbulletin/the-faq-emporium/
    If you are not sure how to do it, then you either need to learn how to do it, or high someone to do it.
    Michael
    Nov 2006
    whats the best way to get power to laptop?
    ill be ordering the contols from a member here that will turn it on when the car turns on, i just need to find a way to power it up.
    whats a good way for this?
    thx
    Mar 2006
    Colorado, but Canadian!
    thx
    Simplest way seeing as how you haven't read too much would be an inverter. I will leave you to read to find out why this is bad. For physically pushing the button, you will need to solder some leads onto your power button, and then when you tap 'em together, on or off it will go. You can also tap them together using a switch. (relay or not)
    1.9in x 2.9in -- 47mm x 73mm
    Elsewhere
    Welcome newbie!
    A good place to start researching your project: New to CarPCs? Don't know where to start?
    More advanced reading for you: http://www.mp3car.com/vbulletin/forumdisplay.php?f=106
    And I disagree with 2k1Toaster... The simplest way of powering a laptop would be a car power adapter for the specific make/model of laptop. But an inverter certainly is a simple solution!
    How about the Wiki?
  1. WTB: 8" Touchscreen Monitor and GPS receiver
    By PutterMcGavin in forum Classified Archive
    Last Post: 01-26-2006, 01:21 PM
  2. BU-303 USB GPS Receiver, Work in sweden?
    By Power_nisse in forum GPS
    Last Post: 07-24-2005, 07:11 PM
  3. GPS wont work.
    By bigmac999 in forum Map Monkey
    Last Post: 07-21-2005, 01:56 PM
  4. Lorty's plugin wont work w/o monitor attatched
    By dudah85 in forum Software & Software Development
    Last Post: 08-07-2002, 11:14 PM
  5. Someone post their results of LCD + GPS
    By Sound of Silence in forum LCD/Display
    Last Post: 03-05-2002, 11:56 AM
