Results 1 to 3 of 3
Thread: HELP!! nROute registyr error with legit mapsource software
    Sep 2006
    HELP!! nROute registry error with legit mapsource software
    I have downloaded the latest nRoute update and it installed with no problems but when I run the program I get this error message:
    "There is a problem with the nRoute registry. Please re-install the nRoute and start it again."
    I have tried several times to re-install the program without success. Has anyone experienced this problem and how do I get nRoute to run?
    Newbie Dingo509's Avatar
    Aug 2005
    Washington, USA
    No answers for you but i have recently had the same problem. It was working fine then after a reformat i reloaded from the same zipped version as before, now i have nothing too! I will Call Garmin tomorrow (have nothing better to do) and if i get an answer I'll post it here.
    Please if you get an answer first post it here!
    Progress: Installed and working. Needs some cleanup and trim work done. now for complete integration.
    91 Jeep Cherokee 8" custom lift, 3/4 ton running gear 36" swampers, Snorkel, Onboard air, Onboard Shower. Now with in dash PC!
    Aug 2006
    Twilight Zone
    Have you try for a solution
  1. garmin mapsource and usb gps mouse
    By thecrow in forum GPS
    Last Post: 09-26-2006, 03:24 PM
  2. Garmin nRoute Software for Laptop
    By rgardjr in forum GPS
    Last Post: 07-11-2006, 02:57 AM
  3. help garmin mapsource and nroute
    By SubaruWRX in forum Road Runner
    Last Post: 12-28-2005, 10:58 AM
