Results 1 to 3 of 3
Thread: Help with th UBLOX LEA-4H
    Nov 2006
    can anyone help me with my project, basically i have to track an rc plane, but i dont want the module to continuosly give me the coordinates, i want to interupt it when i want its position.
    the whole project will consist of the UBLOX module, an sms decoder/trigger circuit (using a microchip PIC) and a gsm/gprs module. when i send an sms to the gsm/gprs module, depending on the sms received, the decoder/trigger will interupt the UBLOX module, causing the UBLOX module to send its coordinates to the gsm/gprs module once, and the decoder/trigger will continue to interupt the UBLOX periodically, until an sms is sent to the decoder telling it to stop the interupts, therefore no more coordinates.
    so i just need help with configuring the UBLOX for a one shot interupt, meaning that a cordinate is only given when the module is interupted.
    here is the picture of the UBLOX module
    and this is how the final project will be made
    some documentation of the module
    LEA-4H_Prod_Summary(GPS.G4-MS4-05018).pdf
    if you need more follow this link http://www.u-blox.com/products/lea_4h.html
    IM AT YOUR MERCY
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    Quote Originally Posted by ishmail View Post
    IM AT YOUR MERCY
    Why not get the serial data of the gps processed by the pic, so you control what is sent by your pic-program?
    Just a thought...
    Nov 2006
    I have thought about it, PROBLEM, the power consumption would never lessen as the system would always be on.
    so if i interupt the system, then, i can allow the pic and the gps module to be on sleep, until the pic receives an interupt from the gsm module and hence also interupting the gps, and consiquently giving me a position
    after a couple of seconds, they would again go back to sleep mode.
    I AM STILL AT YOUR MERCY
  1. Ublox Dead Reckoning GPS
    By jcdillin in forum GPS
    Last Post: 09-10-2014, 01:00 PM
  2. Ublox module , help needed!
    By Laidback in forum GPS
    Last Post: 01-09-2006, 09:40 AM
